Old 12-01-2012, 09:21 AM   #1
Dick Deegan
Dick Deegan's Avatar
Default Copper B Head Gasket
I am just finishing up my engine after a extensive refresh and am about to install a copper B head gasket on an A engine with a 5.5 head.
Which side of the gasket faces the head, or does it matter?
Thanks
Dick
Dick Deegan is offline   Reply With Quote
Old 12-01-2012, 10:21 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Copper B Head Gasket
Why a B gskt?? Is that what manuf recommended??
Paul inn CT
Old 12-01-2012, 11:24 AM   #3
ford3
on a copper gasket, or any gasket one side will be smooth, the other side around the cylinder bores will be a crimp that crimp goes against the head,the idea being that an engine viberation is delevoped by the pistons firing and may cause wear at the crimps, its easier to surface the head than the block to remove the wear
ford3 is offline   Reply With Quote
Old 12-01-2012, 01:03 PM   #4
Dick Deegan
Yes. A "B" head gasket is recommended by Snyder's for the 5.5 head.
Old 12-01-2012, 01:04 PM   #5
Dick Deegan
Thanks ford3. That makes sense and it is the way I will do it.
Dick
Old 12-01-2012, 06:50 PM   #6
Dick Deegan
I don't really know. I bought it from Mac's a couple of years ago. Hope that it works!! I did spray is with copper spray on both sides prior to installing. It looks like the one in your picture.
Dick
Old 12-02-2012, 12:03 AM   #7
Ron in Quincy
Ron in Quincy's Avatar
The head gasket Snyder's recommends for the 5.5:1 head is not a copper head gasket, it is head gasket Snyder's sells that is coated with silicone ; additional high temp silicone bands surround all water passages. Install with no additional sealants.
Snyder's listing: B-6051-M (for 1932-34 and Snyder's 5.1 or 6.1 Head).
Ron
Ron in Quincy is offline   Reply With Quote
Old 12-02-2012, 08:14 AM   #8
Dick Deegan
Thanks Ron. Yes, I am aware of this and have used the silicone coated gasket in the past. I did contact Snyder's at the time that I bought this gasket and they stated that as long as it was a B gasket it should work. We'll see!! The only reason that i am using this gasket instead of the silicone gasket is because I have it in stock. Trying to save a few dollars.
Dick
Old 01-10-2013, 11:18 PM   #9
Tanglfoot
I may be a bit late on this one but I always use a copper asbestos head gasket, the reason is you can always use it a second time in an emergency
Ahooga
Tanglfoot is offline   Reply With Quote
Old 01-10-2013, 11:39 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ahooga
Tanglefoot,
I can just "see" Chief shakin' his head, no, no, that'll just cause ANOTHER emergency about 17 miles down the road!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-11-2013, 05:12 AM   #11
juke joint johnny
juke joint johnny's Avatar
Great Photo Bill !!!! Stuck in mud Pie town New Mexico!!!
John
juke joint johnny is offline   Reply With Quote
Old 01-11-2013, 04:03 PM   #12
BILL WILLIAMSON
John
John,
Pic reminds me of a friend & his daughter, traveling ALONE to Dallas, pulled off the road in a New Mexico DOWNPOUR!! He still has MUD on the muffler, won't scrub off! Bill W.
Old 01-11-2013, 07:42 PM   #13
Tanglfoot
Originally Posted by BILL WILLIAMSON View Post
Tanglefoot,
Bill
18 miles in NZ and I would be home with most of the water intact
What I meant was the other sticky type gaskets have to be scraped off so you have nothing left
Ahooga
Old 01-12-2013, 12:12 AM   #14
BILL WILLIAMSON
Bill
Ahooga
Brother Tanglefoot, I knew what you meant, just havin' a little fun! We could be brothers, with my braces, I often tangle my feet & CRASH!
Chief knew an old man who took 2 used head gaskets, layered them with # 2 Permatex, and ran his '29 Chevrolet for years!! Bill W.
Old 01-12-2013, 12:48 AM   #15
PC/SR
Bill: I'm with Chief and his friend. Plastic, silicone, epoxy, whatever, #2 Permatex is all a mechanic needs. Carry it in your tool kit. (#3 is convenient on occasion.)
PC/SR is offline   Reply With Quote
Old 01-12-2013, 08:53 PM   #16
BILL WILLIAMSON
PC, Dog here, what is that # 3 crap? Maybe that's what I got stuck on my R/F pad, DANG stuff won't wear off!! Goes, TICKY TACK, TICKY TACK, when I go across the hard Pergo kitchen floor, Bill LAUGHS!! Well, he DIDN'T laugh once, when he fell on the same HARD floor and drove his SCHNOZZOLA clean into his face, so, he who laughs longest---------------------------Buster T.
