Old 07-26-2010, 06:32 PM   #1
LeroyM
LeroyM's Avatar
Default 32 Axle & Spring Perch Questions
Is anyone making repro 32-34 spring perches with the round ball shock link?
I've heard different numbers stated on the 32 axle. Is it 1 1/2" or 2" inches dropped or lower then a Model A axle from the factory?
If a Model A axle was dropped the same amount as a factory 32 axle would 32-34 spring perches be a direct bolt on and allow everything else to bolt up and work from the Model A?
LeroyM is offline   Reply With Quote
Old 07-26-2010, 08:31 PM   #2
296 V8
Default Re: 32 Axle & Spring Perch Questions
A 32 to 36 axle will lower a stock A 1 3/4".
The 34 perch bolts may be to short for the thicker ( 2 1/4" v 2" ) A axle.
296 V8 is offline   Reply With Quote
Old 07-26-2010, 08:42 PM   #3
rustythumb
why not just use a stock '33-'36 axle?
rustythumb is offline   Reply With Quote
Old 07-26-2010, 09:03 PM   #4
LeroyM
LeroyM's Avatar
So if you were to use a 33 to 36 axle would you also use the 33 to 36 spring perches?
Is this a direct bolt on with the Model A mechanical brakes and wishbone?
If not what has to be changed?
Old 07-26-2010, 09:20 PM   #5
NealinCA
NealinCA's Avatar
A 33-36 axle is the same configuration as a 32 axle...just not as "heavy" of a forging.
You would get the same drop as a 32 axle and still need to use 32-34 perches...or extend a pair of Model A's.
Here's a little write up I did a few years ago...
http://www.hopupmag.com/index.php?/weblog/article/108/
Neal
NealinCA is offline   Reply With Quote
Old 07-27-2010, 10:06 AM   #6
LeroyM
LeroyM's Avatar
Neal
Neal,
I checked out the article you wrote. You said you used a 32 main leaf spring and 32 shackles along with the other parts. Is there a reason why you can't use the Model A reverse eye spring and shackles?
Do you have any pictures or links of Model A's with fender running this setup so I can see how it looks?
Old 07-27-2010, 10:25 AM   #7
Bruce Lancaster
I was just about to answer your email...brought in the hardware to scrutinize.
I have right here until my boss comes along a Model A perch and a Model 40 '33-4 perch, which is the service replacement for a '32 and dimensionally interchangeable.
Thickness need will be based more on your wishbone than axle...you will shim the axle there but bone will be same thickness for perch.
Forgings were made in many dies, and will be found to vary a bit, but holes should have same spacings.
Putting the two side by side with the line at max diameter of the cone that enters top of wishbone, the two seem to be within less than 1/32 of the same length down there...'34 the shorter but almost indistinguishable dif. Bottoms of cones also align, threads start veryvery close to same place.
Placing the two cheek-to-cheek, the shackle holes are on same center location...V8 is bigger of course.
Balls for shock absorber are pretty close to same level, V8 one extends about one inch farther over than A.
Brake linkage bolt is likely the measure you need the most...hard to compare, but I would say V8 is right about 1 3/4" higher.
Remember '32 axle is not just dropped more, brakes are 12" rather than 11.
Suiggestion: Boltittogether by using '32-4 front brakes. Same basic design as A, but not only larger, they come with excellent cast iron vented drums., like the 1931 A so-called Rocky Mountains...which are nearly unfindable.
Bruce Lancaster is offline   Reply With Quote
Old 07-27-2010, 10:36 AM   #8
NealinCA
NealinCA's Avatar
Originally Posted by LeroyM View Post
Neal,
The shackles are different bore size for Model A and 32-34. Model A are 11/16 and 32-34 are 3/4 in the perch and 7/8 in the spring. Most aftermarket 28-34 reverse eye springs are 3/4". You just need to make sure you can get shackles to fit the perch and spring. We used original style 32 shackles, so we needed the 32 mainleaf.
Neal
Old 07-27-2010, 11:06 AM   #9
kelley's restoration
kelley's restoration's Avatar
alert...alert..alert
i just spent 8 hours of my life trying to figure this out
1) 33-34 axle
2) 32 spindle
3) reversed eye model a spring
4) model a kingpin
5) model a brake actuator
6) 32 spring perch
7) 1/4in spacer (important)on the top of the axle
8) model a shackles
these are the components you need to make it work
i will post pics tomorrow
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 07-28-2010, 09:52 PM   #10
ok so here are some pictures
the first one is of the car at iola before i bought it from my dad..thats me in the blue shirt in the chair
the next ones are of how it looked today. i need to add the leafs back into the spring, and i will be running a 550-16 front. also a t rear spring with a 700-18. there is no way that you can run the 21"wheel with this set up. yes i still need to put in the cotter pins and other misc stuff but i just wanted to get this up here to see the combo of parts that i used to make it work....dropped axle pfffft. lol
[email protected]
Old 07-29-2010, 02:38 AM   #11
barryfromvictoria
there is a 1/4 " difference in length between the perch holes in the the 32-36 axle and perch holes in the model a axle.
barryfromvictoria is offline   Reply With Quote
Old 07-29-2010, 04:41 AM   #12
yep... the good old armstrong method fixed that
tk
[email protected]
Old 07-29-2010, 06:42 AM   #13
LeroyM
LeroyM's Avatar
Looks good, thanks for the pictures. Any reason why you're going to add the leaves back to the spring? Is it going to be to low if not? Also which leaf springs did you remove and how many?
I had 10 leafs in my reverse eye spring from Snyder's and I took out springs 2, 3 & 4 from the top of the pack.
Old 07-29-2010, 08:52 AM   #14
Bruce Lancaster
The difference between the examples I measured above is FAR less than 1/4, less than a 32nd. Probably because of thickness differences in wishbone end forgings.
Old 07-29-2010, 09:01 AM   #15
i had to torque on mine a little it to get everything to slide in. it deffinatly wasn't something that i would worry about if/when i do it again
tk
also bruse, where can i get your new book?
[email protected]
Old 07-29-2010, 09:02 AM   #16
i think its just toooo soft
i am worried about hitting the tierod on the oil pan
but my spring is an origional and the aftermarket springs seem to be stiffer all around
tk
[email protected]
