Old 11-08-2012, 04:25 PM   #1
FlatheadTed
FlatheadTed's Avatar
Default Flasher unit
Has any one used the 6V flasher unit that makes use of the stop light by canceling it out and who supplies this unit .Thanks
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-08-2012, 06:11 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Flasher unit
I found some Bosch 6v units & use my stock 36 tailights.
cheers
Tony
Old 11-08-2012, 10:45 PM   #3
bugsiegel
bugsiegel's Avatar
If you look at post 39 of this linked thread this is the way to make it your self. I believe you will need two filament light bulbs and sockets and all the wiring accordingly.
I need to do this as well but also need part numbers.
There was thread on this last week about a unit which is a bolt in from one of the suppliers and it had built in timers into it that automatically switched off the blinker after a programmed time but I'm not sure where that thread is.
Mechanically Inclined but not Auto Familiar
bugsiegel is offline   Reply With Quote
Old 11-08-2012, 11:02 PM   #4
mrtexas
mrtexas's Avatar
http://fordbarn.com/forum/showthread...t=micro+switch
mrtexas is offline   Reply With Quote
Old 11-09-2012, 12:09 AM   #5
FlatheadTed
Thank you Tony, Bugsy ,Tex .
