Old 10-29-2012, 10:30 PM   #1
TreeTopFlier
TreeTopFlier's Avatar
Default Engine Splash Pans, Installed
I've been looking at installing a pair of splash pans in the motor compartment and looking at the for pictures...
Does anyone have or can link to some pictures of how these puppies look installed? I am specifically looking at how they attach outboard of the motor (frame rails?)
Thanks...
Oregon Enduring A's Chapter MAFCA
TreeTopFlier is offline   Reply With Quote
Old 10-29-2012, 10:42 PM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: Engine Splash Pans, Installed
Yes, they get attached to the frame rails with 3 bolts....and to the engine in 2 spots using the pan bolts.
Jim Parker Toronto is offline   Reply With Quote
Old 10-29-2012, 10:44 PM   #3
160B
160B's Avatar
here are two quick photos
160B is offline   Reply With Quote
Old 10-30-2012, 12:14 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ben,
And they look so spiffy, they're the finishing touch to a Model A engine room & they're most functional in directing proper engine room air flow. Shortly installing black powder coated ones on Vermin, my Avatar car. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-30-2012, 12:27 AM   #5
TreeTopFlier
I like them... are the ones Mac's sells better quality and a better fit worth the extra cost?
Old 10-30-2012, 12:46 AM   #6
BILL WILLIAMSON
TTF,
I don't know, mine came from my '30 that I had to sell. Bill W.
Old 10-30-2012, 01:57 AM   #7
1931 flamingo
1931 flamingo's Avatar
I tend to stay away from Mac's and now deal mainly with Snyder's,Bratton's and Bert's. JMO
Paul in CT
Old 10-30-2012, 03:16 AM   #8
Arlen
Arlen's Avatar
I imagine they all sell the same parts. Not likely more than one person reproducing them. It is worth spending the extra to get the powder coated pans. Leaking gas from the carb will eat regular paint off.
DMAFC
Arlen is offline   Reply With Quote
Old 10-30-2012, 05:49 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
There are at least two makers of the pans. Most have the incorrect oval frame holes, but the one from Howell's has the round holes, so I bought from Howell's. That was a mistake, as they look like they were cut using a pair of dull tin snips.
Years ago I bought a pair from Bratton's and they were much better than the set I got from Howell's.
Why don't the makers put the correct holes in the pans and roll the bead in the front lip? Two easy things to make them much more correct.
Old 10-30-2012, 06:29 AM   #10
willobs
Just installed a set from Mikes afforadable (Powercoated) Fit very well.
willobs is offline   Reply With Quote
Old 10-30-2012, 12:11 PM   #11
CarlG
CarlG's Avatar
I've got a set that I got from Snyders. I'll put them on when (& if) I get the engine back in. They are the powder coated ones, made by Brookville.
Old 10-30-2012, 06:06 PM   #12
Mitch//pa
mounting nuts on the bottom of the frame
cant go wrong with the powder coated shields
