Old 10-11-2012, 10:22 PM   #1
Special Coupe Frank
Special Coupe Frank's Avatar
Default Most potential power out of the Model A engine ?
I am curious as to how far one can reasonably go in boosting the power of the model A, and still have a streetable / reliable machine, in terms of HP output.
Some basic scenarios/parameters:
1) HC head
2) Performance Cam ( so-called Touring grind?)
3) improved induction ( bored-out intake, dual Zeniths, S-berg down draft, Webber down-draft, etc.)
4) Counterbalanced crank & lightened flywheel
5) Larger valves
6) Porting / relieveing ?
7) Insert bearings / pressure oiling
I guess I'm curious as to how much benefit each particular mod would achieve, and their cumulative effect, if combined in the same mill.
What's the practical limit on power out-put w/o turning it in to a "hand-grenade motor" ?
I know we're primarily a restoration-based group, so I really don't want to provoke any controversy; I think I am staying within the realm of mods often discussed and (usually?) tolerated by participants here...
Thanks !
SC Frank
Special Coupe Frank is offline   Reply With Quote
Old 10-11-2012, 10:30 PM   #2
CA Victoria
CA Victoria's Avatar
Default Re: Most potential power out of the Model A engine ?
Dyno sheets fron Pirano's Antique Auto in Texas:
http://modelaparts.net/dynosheets.htm/dynosheets.html
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 10-11-2012, 10:43 PM   #3
Rowdy
I do not have the exact hp in front of me, but an engine built for the GR was close to 90 hp. It had one of Bill Stipes IB330 cams, a Brumfield head and a downdraft carburetor. I do not know what you are considering a touring cam as I have heard many people use the term, but it means something else to individual cam grinders, so results will differ. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 10-11-2012, 11:10 PM   #4
columbiA
In my coupe I run a 33 B with a 5.9 head and OD with 4.11 & 2.94 ratios and no other mods & I can pull all but the steepest hills in OD & cruise at 60 an average.I dont feel that any more power is needed and I live in a mountainous area.
columbiA is offline   Reply With Quote
Old 10-12-2012, 06:11 AM   #5
Loyd Nix
I read up on a Stipes cam and it appears that to max its performance you should also perform several other modifications. It seemed to me that if you are inclined to do a full build it would be the way to go but if you just want to pep up ol' Betsy,as I did, just go with a HC head, a touring cam and a FS ignition. I am quite happy with the improvement.
Loyd Nix is offline   Reply With Quote
Old 10-12-2012, 06:51 AM   #6
eagle
eagle's Avatar
My uncle had an engine built by Ron Kelley for a peitenpol that put out around 100 hp.
eagle is offline   Reply With Quote
Old 10-12-2012, 07:43 AM   #7
MrTube
MrTube's Avatar
Uhoh,
Are we going to see you burning rubber and using the parking brake to slide around corners in NE PA?
MrTube is offline   Reply With Quote
Old 10-12-2012, 08:45 AM   #8
V4F
V4F's Avatar
i believe mine has approx. 80 hp . mild street motor . daily driver .......... nice motor by STAN VERMILE .
V4f
V4F is offline   Reply With Quote
Old 10-12-2012, 10:04 AM   #9
P.S.
I think I just figured out why we keep seeing all the Model A blocks with cracks in them...
P.S. is offline   Reply With Quote
Old 10-12-2012, 11:06 AM   #10
Special Coupe Frank
Phooey.
The ones I'm discovering are stockers, not even re-bored. Some even have original factory pistons and valves.
Not saying there aren't "modified engines" with the same issues...
Old 10-12-2012, 11:07 AM   #11
Special Coupe Frank
Originally Posted by MrTube View Post
Uhoh,
Depends on whether or not I can get my hands on some of Granny Clampett's "Tonic"...
( Hell, I won't even need the car !!! )
SC Frank
Old 10-18-2012, 08:04 PM   #12
jcheshire31
jcheshire31's Avatar
I'd talk to Ron Kelley about building an engine with power. He bought my grandpa's old AA and built an engine for it that he then pulled a flatbed trailer with his speedster on it wherever he went and still cruised around 50. But if that's the case I hope you have a deep wallet.
jcheshire31 is offline   Reply With Quote
Old 10-18-2012, 09:01 PM   #13
James Rogers
James Rogers's Avatar
The old saying still holds true, "Horsepower costs"
Old 10-18-2012, 09:52 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
I agree.
I'd want a counterweighted crank, higher compression head, and a 3.27 rear end or overdrive, and I'd think you'd have a great touring car.
Old 10-18-2012, 10:34 PM   #15
Bill Stipe
Bill Stipe's Avatar
Cruises 70 On Interstate 90 from Iowa to home with pedal to spare and can run 55 MPH in second gear if needed and can peg the speedometer faster then you can believe with all of the above items. 3.54 gears no over drive.
I am so happy with this engine I am working on 6 more for all my cars and trucks.
Building Horse Power --
Bill Stipe is offline   Reply With Quote
Old 10-18-2012, 11:56 PM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
And now we return to our regularly scheduled broadcast! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-19-2012, 05:44 PM   #17
Jordan
Jordan's Avatar
can you give us more details about the motor. What kind of belt & pulley system is that?
Cowtown A's
Jordan is offline   Reply With Quote
Old 10-19-2012, 07:04 PM   #18
Bruce,Upstate NY
What is the black box on the steering column?
Bruce,Upstate NY is offline   Reply With Quote
Old 10-19-2012, 09:35 PM   #19
Bill Stipe
Bill Stipe's Avatar
Well Frank said it all in his first post on the topic!
1) HC head
5) Larger valves
I also run a light Alum flywheel with iron insert 25#, 7 to 1 CR head that I welded the chambers up and recut.
And then a new quality camshaft, but I can't say much here seems most guys have there mind made up on that one, all I can tell you is stay away from toooo much duration there is more then just lift and duration to a cam design.
Stay away from too much valve spring pressure these are basicly tractor engines with lots of torque high spring pressure just uses HP and is hard on the valve train.
Make sure everthing is blue printed and in perfect alignment. line hone is a must, no twisted or bend rods! and Balance every thing to the closest specs.
If you pressure the oil system again stay away form high pressure. High volume is more important that every thing is getting oiled, this engine ran a 20 # i wanted 35 but drilled a little too large of hole to squirt on the cam gear. I went back in to change that and wanted to look at every thing after a grueling 1600 miles and all my bearings look like the day I assembled them.
To me a centrifugal advance dist is a must for performance.
Also if you have a helper he has to be alert and not sleeping like my helper seems to be most the time!!
PS: the black box is for the nitrous!
I have a centrifugal advance dist so I use the spaark lever for my turn signal.
Old 10-19-2012, 10:44 PM   #20
Jordan
Jordan's Avatar
1) HC head
5) Larger valves
Do you build engines for other people, or just yourself?
Cowtown A's
