Old 10-03-2012, 11:29 AM   #1
Harylufa
Harylufa's Avatar
Default Gas Tank out of the car
Dear Friends
I have just took the gas tank out and I see much oxide inside. I need some suggestions
1) What to do with all this oxide, cleanings, should open the gas tank with any expert? drain plug is locked
What do you do when your gas tank is with oxide?
2)I have been reading here in Fordbarn this post:
https://www.fordbarn.com/forum/showth...=pump+electric
I think is very interesting this kind of circuit or bypass, I thought about installing another copper pipe for excess fuel/gas as I need 3 PSI to carburetor. As I have the gas tank outside.
I have an electric fuel pump called Facet 4PSI to 7PSI.
It is important your suggestions as I have the gas tank outside.
Hary.
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 10-03-2012, 11:39 AM   #2
TonyM
TonyM's Avatar
Default Re: Gas Tank out of the car
I used the POR 15 system to clean my tank.
TonyM is offline   Reply With Quote
Old 10-03-2012, 01:28 PM   #3
Henryat1140
Henryat1140's Avatar
Are there any radiator repair shops there? I had my tank boiled out at one nearby. Afterwards I sealed it with a product called Redcote.
Here we have Ethanol in the gas and Redcote has a version that is made to withstand Ethanol - don't know what the situation is there.
Good luck and keep posting.
Henryat1140 is offline   Reply With Quote
Old 10-03-2012, 04:42 PM   #4
Harylufa
Harylufa's Avatar
Hi!
Yes I found someone that can clean deeply my gas tank, he has some specials products.
We have nafta here, this tank will be clean after 30 years, it it time to do this
Than you.
Hary
Harylufa!
Old 10-04-2012, 07:38 AM   #5
31chevy
31chevy's Avatar
I also have used POR 15 on three tanks worked well.
Gary.
31chevy is offline   Reply With Quote
