Old 09-28-2012, 12:24 PM   #1
Cape Codder
Cape Codder's Avatar
Default Distilled Water in Radiator
I have had my motor rebuilt and hopefullly it is as clean as can be inside. Also I had a radiator recored so I'm thinking that is as clean as it will get. Question: Is it a good pratice to use Distilled Water in the cooling system and add alcohol for winter operation? If it is good to do how much alcohol should I add? Lastly, where could I get enough alcohol to do the job and are there different types for this application?
Thanks for your time.
Joe Grobleski
Cape Codder is offline   Reply With Quote
