Old 09-22-2012, 02:26 PM   #1
PepeLoco
PepeLoco's Avatar
Default Do you use Mounted Dripping Oil Catch Pans?
Ok, I know the saying, that dripping oil is normal. My household CEO just doesn't like the oil spots on the driveway and in the garage.
I heard one of y'all mention that you mount oil catch pans under the car to catch these drips. So I started looking at all the drips and realized I need to fabricate three to five of these. Trying to figure out how to mount them too.
Can y'all post some pics of how and where you mounted these?
How strong is the air flow and did your pans bend when driving?
What did you make the pans out of? Tin? Roof Sheet metal? Wife's pots/Pans?
Thanks,
Pepe
PepeLoco is offline   Reply With Quote
Old 09-22-2012, 04:45 PM   #2
Ed Saniewski
Ed Saniewski's Avatar
Default Re: Do you use Mounted Dripping Oil Catch Pans?
I bought one years ago and used it for about three days. I will sell it for $10.00 plus shipping. You can then make copies of it. Ed Saniewski
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 09-22-2012, 04:52 PM   #3
SDJason
SDJason's Avatar
permanently mounted to the car??!??
Why not just get a few of these @ $12 each...
SDJason is offline   Reply With Quote
Old 09-22-2012, 06:51 PM   #4
1931 flamingo
1931 flamingo's Avatar
Better yet, try to "fix' the leaks if there are that many, Sometimes tightening something will stop a leak..................
Paul in CT
Old 09-22-2012, 06:52 PM   #5
Vern
Vern's Avatar
When I bought my roadster the previous owner gave me a heavy duty baking pan, about 2' x 3'. I made a frame for it with perforated "L" metal, mounted small casters at the corners & spread out kitty litter. It easily rolls under the A, and out of the way. Only problem is the &@$?# cat occasionally uses it!!
Vern is offline   Reply With Quote
Old 09-23-2012, 02:01 PM   #6
juke joint johnny
juke joint johnny's Avatar
So Vern
Does that mean you have a cat covered in oil rolling around on the sofa !
Man your looking for Trouble !!!
John Cochran
juke joint johnny is offline   Reply With Quote
Old 09-22-2012, 08:01 PM   #7
CarlG
CarlG's Avatar
Snyders (and others) sell these:
Put an end to those unsightly puddles of oil on the garage floor or the driveway! Slips over the bell housing bolts and one of the flywheel dust cover bolts. Install or remove in seconds, catches all of the oil leaking out of the rear main bearing. Powder coated black. U.S.A.
Old 09-23-2012, 10:02 PM   #8
cpetku
Just remember with these catch cans/pans, you have to empty them. Otherwise it just fills up and drips on the floor again. I have a coating of kitty litter on the floor of the garage under the A and just change it out occasionally.
1931 Roadster
cpetku is offline   Reply With Quote
Old 11-03-2017, 12:58 PM   #9
Chris Haynes
Chris Haynes's Avatar
How do you drain it?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 11-03-2017, 03:08 PM   #10
CarlG
CarlG's Avatar
When I used it, I lined it with oil absorption pads & just changed them out when they were soaked.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-22-2012, 10:08 PM   #11
columbiA
If the car is restored to new condition,you will not have puddles every where.You could use a large sheet of card board from a fridge ,stove etc & throw it away when too saturated.Trays from old kitchen ranges work good too.
columbiA is offline   Reply With Quote
Old 09-22-2012, 11:23 PM   #12
sturgis 39
I bought some trays from Wal Mart. They are in the Automotive section. They are about 1.5'x3.0' . My garage floor is treated plywood. I went to a heating, ventilating and air conditioning contractor and bought a 4'x16' piece of sheet metal and nailed it to the floor. I use the Wal Mart tray under the engine and transmission and the sheet metal from the HVAC contractor catches the miscellaneous drips. The plywood is cleaned with paint thinner if oil drips on the plywood. The floor looks almost like new.
I do not worry about puddles except in the garage.
Looking at most parking lots, there are lot of cars other than old Fords that drip oil.
The Model "T" Club slogan is " If it is not dripping oil, it is out of oil".
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 09-23-2012, 11:42 AM   #13
Napa Skip
Napa Skip's Avatar
Don't know how others do it but what our club did for a recent tour to the Jelly Belly factory was - for those of us who had known "leakers" - (a) take two small sections of cardboard (don't have to be too large and in fact - partially due to the shade in the accompanying photo below - hard to see) that can be slipped under (typically) the rear of the engine/transmission and under the differential to catch any errant drips and (b) assigned one individual to police the parking area just after we pulled away to wipe up anything that was not caught by the cardboard.
[Around here, the Jelly Belly factory is as close to a historic building as we get...]
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 09-23-2012, 02:41 PM   #14
Jordan
Jordan's Avatar
Show me a garage floor that doesn't have oil stains, and I'll show you a garage that doesn't have a Model A in it.
Cowtown A's
Jordan is offline   Reply With Quote
Old 09-23-2012, 05:06 PM   #15
1932BB
mot
Is it necessary to use a Maxwell House coffee can? Would any other brand can be "Good to the Last Drop?"
1932BB is offline   Reply With Quote
Old 09-23-2012, 07:36 PM   #16
Clem Clement
Clem Clement's Avatar
When parking you can use plastic trash bags. The drips seem to curl the pastic and the oil doesan't seem to run. Rollit up as you leave and put it in another bag
Clem Clement is offline   Reply With Quote
Old 09-23-2012, 08:56 PM   #17
Mikeinnj
Mikeinnj's Avatar
This clear spray Permatex product stopped a leak on both my trans and differential. Applied from outside the leaking parts, but parts must be cleaned off really good. Apply three coats and allow to dry overnight. Not cheap but effective.
http://www.permatex.com/products/aut...eak_Repair.htm
Mikeinnj is offline   Reply With Quote
Old 11-02-2017, 11:43 PM   #18
Dino's A
Dino's A's Avatar
Linky no worky.
Dino's A is offline   Reply With Quote
Old 11-02-2017, 11:58 PM   #19
cpf240
cpf240's Avatar
Originally Posted by Dino's A View Post
Linky no worky.
That post is over 5 years old...
cpf240 is offline   Reply With Quote
Old 11-03-2017, 10:59 PM   #20
updraught
updraught's Avatar
Linky no worky.
Probably this:
https://www.permatex.com/products/ad...t-leak-repair/
updraught is offline   Reply With Quote
