Old 09-18-2012, 08:26 PM   #1
Rubatoguy
Rubatoguy's Avatar
Default Model A Engine Removal from car
1st timer at engine removal with hoist.
Do I have to take the engine and transmission out at the same time, or is there a way to remove the engine while leaving the transmission in the car?
I'm looking to do what is easiest.
thanks,
Todd
Rubatoguy is offline   Reply With Quote
Old 09-18-2012, 08:30 PM   #2
bogdonj
bogdonj's Avatar
Default Re: Model A Engine Removal from car
some guys remove the engine and tranny as one but I find it easier to just remove the engine if that's all your working on.
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 09-18-2012, 08:45 PM   #3
jkeesey
jkeesey's Avatar
Ive always found it easiest to leave the trans in the car and pull just the engine. Its pretty straight forward on removal pull the flywheel housing bolts and everything on the front and the engine will slide away from the transmission.
jkeesey is offline   Reply With Quote
Old 09-18-2012, 08:49 PM   #4
ScottNW/Ohio
ScottNW/Ohio's Avatar
My vote would be pull the entire assy (engine and trans together)
It would be less hassle trying to re-install the engine with the trans still in the car and trying to keep it "blocked" in place
Especially if this car is "new to you" you may want to inspect the trans bearing and the universal joint
Just my opinion
Scott
ScottNW/Ohio is offline   Reply With Quote
Old 09-18-2012, 10:22 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I like to leave the tranny in the car and support it on a floor jack, or use a 2 x 4 and ratchet strap to support it.
Old 09-18-2012, 10:59 PM   #6
msmaron
msmaron's Avatar
Why Tom that looks like the Ole Chipper back in the day!!
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 09-18-2012, 11:33 PM   #7
Tom Wesenberg
Yep, that's the one back in it's not so glory days!
Old 09-19-2012, 01:55 PM   #8
Fred K-OR
Fred K-OR's Avatar
Just my opinion
Scott
I also vote with Scott. I have only pulled an engine and tranny a couple of times but I prefer to do both.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 09-19-2012, 05:03 PM   #9
RonC
RonC's Avatar
When you reinstall the engine you can open the bell housing access plate, reach in and rotate the transmission spline so the engine will mate.
RonC is offline   Reply With Quote
Old 09-19-2012, 05:15 PM   #10
Jerry Parr WI
Jerry Parr WI's Avatar
Obviously it can be done both ways. I prefer to pull the engine separately. Pulling them together requires removing the pedal assembly and the trans cover. Then you need to cover the trans to keep out junk. It also leaves you dealing with a larger heaver assembly. I made two heavy wire hooks to hang the transmission from the motor mounts. Serves the same purpose as Tom's 2X4. I also find it easier to reassemble them separately.
Jerry Parr WI is offline   Reply With Quote
Old 09-20-2012, 08:18 AM   #11
jw hash
jw hash's Avatar
I will add one more little tid bit, if you only pull the engine you can leave the head light bar on, the 28-29 that is no big deal but the 30 -31 can be a pain.
jw hash is offline   Reply With Quote
Old 09-20-2012, 09:22 AM   #12
TinCup
TinCup's Avatar
For me it depends on what needs to be done. If you have been thru the tranny and ujoint before just pull the motor. If you haven't then pull them as a unit. Make sure you have one of these they make it so much easier.
Head Puller
TinCup is offline   Reply With Quote
Old 09-20-2012, 09:38 AM   #13
Tinker
Tinker's Avatar
Tom, Geez, why didn't I think of that! 2x4 and strap, simple and direct. Much better then just the jack alone.
Old 09-20-2012, 01:40 PM   #14
walt jones
walt jones's Avatar
Tom's ideas are always good. I varied his approch by threading allthead down on each side into the tansmission top bolt holes. It was long enough to reach up through holes drilled in a two by four mounted across the car just above the transmission. I slid fender washers over the allthread down against the top of the two by four. I then ran nuts down against the washers and used them to for adjustment and support of the transmission.
Walt
walt jones is offline   Reply With Quote
Old 09-20-2012, 03:07 PM   #15
sturgis 39
I have always pulled just the engine. Installing the engine can be hard. The frame, sometimes, needs to be spread so the rear engine mounts will a slide in the frame. This is kind of tough when working alone. I built a frame spreader from some angle iron and placed a Porta Power on the floor.The frame spreader was made out of three pieces of 1/4x2x2 angle. The angles where just bolted together and this provided a hing when the Porta Power was energized.
Last time I installed a Float a Motor mounts from Sacramental Vintage Ford. This made installing the engine a one man operation. No frame spreader was required, just a pin bar for aligning the holes.
I use a lifting eye that screws into the spark plug hole.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 09-21-2012, 10:55 AM   #16
wi0v
wi0v's Avatar
I just pulled my engine and had it overhauled. Pulled engine only using a Harbor freight engine leveling bar and two lifts in the #2 and #4 spark plug holes. Held the trans up with a strap and 2x4. When going back in, used all thread about 8 inches long to align the trans to the engine and if you use the two piece crankshaft pulley you can leave the pulley off until you get the engine back in. Took less than an hour working by my self.
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
wi0v is offline   Reply With Quote
Old 09-21-2012, 11:37 AM   #17
Rubatoguy
Rubatoguy's Avatar
At least it will not be a one-man operation. I have a helper!
I will probably just pull the engine as the transmission was recently rebuilt and should be good.
Old 03-11-2013, 03:48 AM   #18
Rubatoguy
Rubatoguy's Avatar
So, I decided to just pull the engine, I removed all the bolts around the flywheel, the front engine mount, and rear engine mount bolts, and gas pedal assembly. I can lift the engine up and down, and I have about a quarter-inch separation between the engine and bellhousing, but I can't get the engine to move forward. (I have the transmission strapped with a 2x4.) I don't want to lift up too much as I don't want to crack anything. It seems the engine should just slide forward, but no luck. Should I try to tap out the rear mounts? Any suggestions?
thanks,
Todd
Old 03-11-2013, 04:16 AM   #19
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Try raising the tranny a bit, I think your shaft is binding.
Old 03-11-2013, 06:45 AM   #20
Dick Deegan
Dick Deegan's Avatar
I use a long pry bar to pry the engine off the tranny, especially from the bottom. Just make sure that everything looks to be lined up before prying. You do not want to bend anything. If you look at videos on U Tube, most show the mechanic using a pry bar.
Good Luck
Dick
Dick Deegan is offline   Reply With Quote
