09-15-2012, 03:17 PM | #1 |
Steering box help needed
Hey there folks. I am putting my 2 tooth box back together after a refresh. Everything was going good till I went to tighten the sector housing down. The Les Andrews book says to tighten the housing down then install the Sector thrust screw. I tighten the nuts for the housing and went to turn the steering shaft and it was locked up. If i loosen the nuts and it will turn freely. I thought maybe I could use the thrust screw to adjust it but with no luck. Any advice or thoughts would much appreciated.
Drew |
09-15-2012, 03:25 PM | #2 |
Re: Steering box help needed
Try turning the eccentric nut one way or the other.You are trying to tighten the cover down with the sector adjusted too tight to the worm.The angle of the gears makes it tighter still as you tighten it down.
09-15-2012, 07:08 PM | #3 |
I just went through the same rebuild on my 2 tooth column. You need to loosen the housing cover nuts 1/4 turn, then adjust the eccentric adjusting nut. I still couldn't get mine loose enough when the wheel was centered, so I had to adjust the "Centralization Rivet" back to where it had been. In Les's book, he tells you to set it to the vertical position when doing a rebuild. Mine had been off to one side slightly before I replaced the sector shaft but not the worm gear. I set it back and the steering is great.
Try the eccentric nut first.
1930 Pickup in Prior Lake, MN |
09-15-2012, 10:39 PM | #4 |
Keith and hook, I did read that part of the book. I figured that because i did not replace the sector that it would just go back where it was before. I will try the eccentric nut in the morning and get back to yall. Also I noticed that when rotating the steering shaft from stop to stop it turns freely then tightens up at about center then frees back up. This of course while the housing nuts were not snug.
09-16-2012, 11:26 AM | #5 |
It is supposed to be tighter in the center
09-16-2012, 02:18 PM | #6 |
09-16-2012, 03:52 PM | #7 |
I have found that I don't get an accurate adjustment on a 2-tooth until it's installed and the car is sitting on the ground.
