#1 |
What do you think and where can I find Amber lenses? I had this idea for a third brake light..use a tailight and use two clamps with rubber inserts to protect the spare wire wheel. Not hooked up yet....so thinkng about front turn indicators...(held in place for the photo but bracket in the future) use the same rear taillights but change to amber lenses if anyone makes them. Certainly not original but would keep me from having to use hand signals and would look more "Authentic".
What do you all think of it and does anybody know of amber lenses for sale?
"The Family Ford" |
#2 |
I hooked up my turn signals to my cowl lights and wasn't satisfied with white turn signals. You can get amber colored lenses for 30-31 cowl lights but not for 28-29.
I was pointed toward stain glass paint by a fellow Barn member. You can get it from large hobby chains or hobby glass shops. I could not get amber however so I settled on yellow and red and experimented and bit on a pane of glass until I got the color I wanted. It thins with water and is probably an acrylic paint and is very inexpensive. Thinning it a good bit once you have the desired color helps and keeps the paint from overpowering the low watt bulbs. It only takes a thin coat to color the lense and show up amber. If you make a mistake the paint readily peels right off. Experiment on a piece of glass before you paint it on a clear lenses. Clean up with water. I believe you should be able to completely remove the color on the repo stop light lenses with paint remover and tint them any color you want. Hope this was helpful. |
#3 |
You can go to Harbor Freight, or Northern Hydrolics, Fleet Farm, Tractor Supply or other type store and purchase amber marker lights for trailers and use them for the front turn signal lights. Red ones can be used for the rear. You can mount them between the bumpers and use the bracket that goes on the center front emblem in the bumper for a back on the lights. Works great.
#4 |
Our favorite auction site has these up. There's an amber lens in the group.
![]() http://www.ebay.com/itm/1928-1931-MO...b5c85b&vxp=mtr |
#5 |
Thanks Barb...I'll bid on them...also ivoryjohn thanks for spelling it out so well. I asked my good friend Pat what he thought of the idea and he was for it...I always like to ask the more seasoned model A'ers what they think because I value their opinions.
"The Family Ford" |
#6 |
#7 | |
![]() Quote:
Yea I think the cowl lights look a little strange but don't like the plastic looking ones that go on the bumper. Lets face it anything you put on that isn't original looks out of place in MHO. Tail lights hanging on the front bar? Seriously? But to each his own and the object is to get their attention when you are turning. The best turn signal I have seen is the giant Mickey Mouse hand! That got my attention but it made me want to wave back not watch for a turn. So fly backwards if you want to. |
#8 |
Ivoryjohn, I am laughing...the Mickey mouse hand sounds humorous...I could get my kids to signal the turn out the Tudors Window but I have the feeling they'd be doing it more than I was actually turning...and yes I agree the whole idea is different but I really am not partial to the signals I have seen in the bumper etc...that why I chose the style that the rear lights have with the modern convenience of turn signals...
"The Family Ford" |
#9 |
Napa 1506ad. Under 10 dollars ea! 12volts, but take out bulb and replace with a 6 voltBUlb. Trying to send picture ,but having trouble
#10 |
One of the guys in our club uses Harley turn signals in the front, mounted under or next to the headlight on the headlight bar.
I personally just use the cowl lights. They seem to be a lot more effective than the little plastic things that mount between the bumper rails. I have the amber lenses for the cowl lights but have never put them on. The white light up high like that is quite noticeable to oncomming traffic. |
#11 |
#12 |
Never thought about it - but I like the "look" of the tailight housings for turn lights
I have the bumper mount ones from Snyder's - but look 'out of place' |
#13 |
personally i like the period correct yellow fog lights turned to signals.
#14 |
HOBBY LOBBY sells "Citrus Yellow" "Window Color Paint" that can be used to paint your turn signals for $2.25.
#15 |
Scott, I do too...i think if they manufactured forward turn indicators, they might have looked similar to this...maybe it'll be a trend. I like that I can mount them forward near the headlights similar to the positioning for modern cars....I like the paint posts too...I will likely buy the lights from speedway at 22 dollars a piece to make it affordable then get the turn switch from them too. I want to drive in the colder weather so le aging a window rolled down to hand signal might have its downside. Kris
"The Family Ford" |
#16 |
On my 30 coupe,I made a bracket off the lower 2 bolts on the spare tire mount & mounted a red lite about 1-1/2"x5" in behind the spare tire & the lite shines thru the spokes & makes a great middle brake lite.This way you dont have to remove the lite when you need to use the spare.
#17 |
Smiling...I hope I don't have to use the spare...by the way what does it feel like when you get a flat while you are running...front vs rear? Curious about that...and I like the hidden bracket...cool idea
"The Family Ford" |
#18 | |
![]() Quote:
Bad is a blowout on the rear tire of a motorcycle. Contrary to popular belief, a flat on the front of a motorcyle is better than a flat on the rear. On the front you have direct control of the steering......not so on the back. |
#19 |
Got a set of NOS Honda turn signals from Amazon. Chrome and don't look too bad. Looking for safety over being authentic. Really bright also.
#20 | |
![]() Quote:
Not sure if that is completely correct. I seem to recall checking New Jersey state law a year or 2 ago and found Amber was legal as a brake light. If my memory is correct than this would obviously mean it depend on the state. However I do agree everyone expects RED for stop. |
