07-16-2010, 11:38 AM | #1 |
front fender brace, which is correct?
IM restoring a 29 Model A pickup. My pickup frame was made November 1929. I have a pair of front fender braces that are stamped steel with two holes over top of each other, where they bolt to the frame. Are they correct for my pickup? I have the cast iron (1928) style with three mounting holes on the bottom, two small holes and one large one. I've also seen a 30/31 stamped steel brace with 3 mounting holes on the bottom that are all the same size. Thank you for your help.
07-16-2010, 01:37 PM | #2 |
Re: front fender brace, which is correct?
http://www.abarnyard.com/ |
