Old 07-15-2010, 06:35 PM   #1
Ziffer
Default Cutoff Wheels (3M is getting too expensive)
I'm looking for input here on abrasives. I love the 4" 3M Green Corps 1/32 wheels for cutting but they get more expensive every day it seems. I've tried Metabo and they just don't get the job done. Sait are okay but not the best. What are you guys using that cuts aggressively, the wheels last, etc.
Thanks
Russ
Ziffer is offline   Reply With Quote
Old 07-15-2010, 06:59 PM   #2
metalman
metalman's Avatar
Default Re: Cutoff Wheels (3M is getting too expensive)
I think I've used just about every one out there. Yes, the 3M green corp are by far the best, last the longest, but just way too $$$. I use only Sait now, I feel they are the best value. They might last only half as long as the 3M but cost 1/3 as much. Most of the brands IMOH around the same price or less then the Sait are worthless.
FWIW I always try to use the 3" x .035 for cutting sheet metal and only Sait and 3M have them that thin that I can get around here.
metalman is offline   Reply With Quote
Old 07-15-2010, 07:01 PM   #3
Uncle Bob
Uncle Bob's Avatar
Everything else I've tried just doesn't hold a candle to the 3M wheel for how long they last, though they're expensive they last, so real cost is competitive.
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 07-15-2010, 07:20 PM   #4
Ronnie
Ronnie's Avatar
Norton charger or evo tough to beat
Ronnie is offline   Reply With Quote
Old 07-15-2010, 07:37 PM   #5
Frank The Plumber
Try www.colonialtools.com, see what they have.
Frank The Plumber is offline   Reply With Quote
Old 07-15-2010, 08:48 PM   #6
thunderbirdesq
thunderbirdesq's Avatar
I've had good luck with the Dewalt 4.5" cutoffs. That said, with my next build, I'm gonna do something I shoulda done a loooong time ago. Buy a plasma cutter!
thunderbirdesq is offline   Reply With Quote
Old 07-15-2010, 09:29 PM   #7
Dave72dt
I've had good luck with the Dewalt 4.5s also. They're only costing me $2 each at my local Tractor Supply. As long as I don't crowd them, they last well.
Dave72dt is offline   Reply With Quote
Old 07-15-2010, 09:58 PM   #8
Frank Cowan
Frank Cowan's Avatar
I use the cheapest I can find... harbour freight. The 3 inch are $7 for 10 and the 4.5 inch are $8 for 10 both on sale half the time. I use a lot of them. I bet others last longer.
Frank Cowan is offline   Reply With Quote
Old 07-15-2010, 11:37 PM   #9
Steel 35
Steel 35's Avatar
Flexovit, Sait are the two I am using, I only get the ones with the cup no flat ones I believe there 4.5 and the guards are off, yes I have had my thumb stiched back on, I know they cut well and I have a phobia of them but some things ya can't do with a guard on. ....I use them to support my old ford.
Steel 35 is offline   Reply With Quote
Old 07-16-2010, 02:31 PM   #10
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
We have the harbor freight ones stuck in the ceiling, and even have stitches from them after they blew up and cut thru our legs.
Spend the money......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-16-2010, 02:43 PM   #11
John Kennedy
John Kennedy's Avatar
The cheap ones scare me. I don't use them.
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 07-16-2010, 03:18 PM   #12
53ash
53ash's Avatar
I cut about 1/2 way through my left fore finger when a Dewalt went to heck, but that was my fault, not the blade. That is usually the problem.
Dewalt does a good job for us. We work with Stainless daily at my business, and they do a good job on our sheet metal.
We carry: Amsoil Synthetic Lubrication products
53ash is offline   Reply With Quote
Old 07-16-2010, 10:21 PM   #13
hbleadsled
I use 3m and harbor freight NOW you guys scare the hell out me. no more harbor freight for me.
hbleadsled is offline   Reply With Quote
Old 07-17-2010, 05:14 PM   #14
MLK
Lawson's are good, but expensive. I quit using cheap cut off disks....too many people have had them come apart, and I hate changing out a disk every few minutes because they wear out so quickly.
Mike
MLK is offline   Reply With Quote
Old 07-17-2010, 06:55 PM   #15
Fordors
Hi guys, I was a regular at the old Barn under a different name; first time poster at the new place. The new 'site is great, lots less BS and no back biting here.
I had a pretty serious injury about 30 years ago from a cutoff wheel. I was working on my 5 window, wearing my GM issued safety glasses when I had a wheel grenade immediately upon start-up. A chunk went under the frame of the glasses and I received 15 stitches at the ER. I never, ever use a c/o wheel without a full face shield anymore.
The wheel had most likely gotten a nick in the edge when I had last set it down and as soon as it got up to speed whamo! That one was a little too close. I would recommend anyone to look for a nicked wheel, hold the tool away from you when you first start the spindle, and consider the face shield.
Also, yesterday I saw this thread and I e-mailed Sandusky/Chicago Wheel. I think they were the manufacturer of the wheels I used to get from GM (never mind!) BITD. They worked great; 3" X 1/32 with a 1/4" hole. As soon as I find out pricing and where available I will post the info.
Fordors is offline   Reply With Quote
Old 07-17-2010, 09:07 PM   #16
HOTRODPRIMER
HOTRODPRIMER's Avatar
I have had good luck with the Dewalt 4.5" cutoff wheels,,HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 07-17-2010, 10:56 PM   #17
andyg
andyg's Avatar
Pferd or pferdd is the best I have ever found. They last a long time and are very thin. Made in germany but a quaility cutoff wheel indeed. I will correct the spelling on this post when i get back to the shop.
andyg is offline   Reply With Quote
Old 07-18-2010, 08:49 AM   #18
jdl
jdl's Avatar
Send a message via ICQ to jdl
I have never used this brand but here is the link..
http://www.pferdusa.com/products/206/index.html
jdl is offline   Reply With Quote
Old 07-18-2010, 09:26 AM   #19
skip
Banned
"I love the 4" 3M Green Corps 1/32 wheels for cutting but they get more expensive every day it seems."
You pay for what you get. Buy the best. I agree mis use these in the slightest and they will come apart and kill you.
We used thousands of these when building a Palmer Johnson Yacht. Along with about 17,000 Milwaukee saw 'Z All blades per hull.
skip.
skip is offline   Reply With Quote
Old 07-18-2010, 10:27 AM   #20
gearheadbill
gearheadbill's Avatar
You might try, as I did, to find them on Ebay. I recently bought 40 packs of 5 discs for less than $100. Not always available but I got lucky.
gearheadbill is offline   Reply With Quote
