Old 08-13-2012, 10:02 PM   #1
329s
Default 28-29 vs 30-31 forged front fender brackets...
Just how does one tell the difference between the 28-29 and the 30-31 forged steel front fender brackets?
Thanks.
Pluck
329s is offline   Reply With Quote
Old 08-13-2012, 10:24 PM   #2
Roadster62
Roadster62's Avatar
Default Re: 28-29 vs 30-31 forged front fender brackets...
Bolt holes for the headlight bar are spaced differently from the frame 28-29 vs 30-31. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 08-13-2012, 10:39 PM   #3
Marco Tahtaras
Marco Tahtaras's Avatar
The shape of the fenders and thus the shape of the brackets are DRAMATICALLY different! '28-29 fenders have a very narrow crown while the '30-31 fenders have quite a broad crown. Once you focus on the shape you can spot the difference at 30 feet!
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 08-14-2012, 12:45 AM   #4
Randy in ca
Randy in ca's Avatar
Another way to tell them apart at a glance is to check the flange where the bracket bolts to the frame:
On the 1928-29's the flange is much thicker at the lower bolt hole than it is for the 2 upper bolts. As well, the lower uses a 1/2" bolt while the 2 upper ones are 3/8".
The 1930 brackets have the thinner flange uniform for all 3 holes and use all 3/8" bolts to attach.
File Type: jpg 1928-29 Forged front fender brackets #1.jpg (55.7 KB, 77 views)
File Type: jpg 1928-29 Forged front fender brackets #2.jpg (59.0 KB, 76 views)
Randy in ca is offline   Reply With Quote
Old 08-14-2012, 09:44 AM   #5
wrndln
What Randy said is correct. I find it the easiest way to tell them apart even though as Marco said, the crown or arc on the top is much wider io the 30 brackets than the 28/29's. The lower mounting bolt hole is the way to differentiate the two - thin 30 hole, thick hole 28/29.
Rusty Nelson
Old 08-14-2012, 10:30 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
Here is a few of mine . The gray primed ones and the three rusty ones next to them are 28-29 The distance from where they connect to the frame, to the holes for the headlight bar is closer on the 28-29 than they are on the early 1930 forged brackets. The brackets to the right are a mix of 30-31 stamped brackets and 1930 forged brackets.
Old 08-14-2012, 10:43 AM   #7
329s
Thanks guys...you were a great help on this one.
Pluck
Old 11-12-2021, 08:37 AM   #8
Screwdriver
Do you have a set of front fender brackets for a 29 that you will sell
Screwdriver is offline   Reply With Quote
Old 11-12-2021, 06:01 PM   #9
hudson32700
Where are the pictures Purdy Swoft?
hudson32700 is offline   Reply With Quote
Old 11-12-2021, 06:19 PM   #10
Dennis Pereira
Dennis Pereira's Avatar
That's an old post look at the date
Old 08-14-2012, 07:30 AM
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
