Old 08-05-2012, 01:03 AM   #1
my4dv8
Default Headlights stuck on high
Just a question as we have found the answer but not the solution. We have a 32 v8 with 1930 model A headlights and this weekend while on an early morning run ( very early) the lights stuck on what appeared to be high , well indicator light was on and ammeter was show pretty low.Chased the problem here and there but found the bulb holders we got from Macs were touching terminals. The contacters that slide throught the red insulator in the bulb holder were not straight ,we fiddled around and got them bent to stay apart kind of but has anyone else had this issue ,and found a better way. Car is 8 months on the road.
my4dv8 is offline   Reply With Quote
Old 08-05-2012, 06:07 AM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: Headlights stuck on high
Repro three pin contacts are terrible. I had to grind down the OD of the contacts so they wouldn't touch, also the pin guides are sloppy allowing them to move around. No good solution for that unless you use the originals. I didn't have any problem after I ground down the diameters.
Barry B./ Ma. is offline   Reply With Quote
Old 08-05-2012, 07:48 AM   #3
tdlmomowers
tdlmomowers's Avatar
We had the same problem on my son-in-law's 28 Model A. The repo sockets are junk. We hard wired the sockets with spade connectors so we could dissassemble the lights easily. Now we have good tight connections. I don't like working with 90 year old technology. Sorry, to all the purists, but some things have been improved over the years.
tdlmomowers is offline   Reply With Quote
Old 08-05-2012, 09:50 AM   #4
KGBnut
KGBnut's Avatar
I agree, the repros don't have the required tolerances. I made the mistake of installing them on mine. I've now decided to try and recondition my originals and reinstall them. Failing that, I will hard wire them like tdlmomowers said.
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 08-06-2012, 01:29 PM   #5
Franchise_24
Franchise_24's Avatar
One of the best things we did to that car
Very frustrating trying to get those lights to work properly with that new harness.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 08-06-2012, 01:50 PM   #6
sethkestenbaum
sethkestenbaum's Avatar
Does anyone have any images of how they did their hard-wiring or newer connectors? I am looking for suggestions on how to do mine.
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
