07-29-2012, 02:04 PM | #1 |
Shifting Issue
I'm having trouble shifting my 31 coupe. After sitting several years, I got it running but as I started driving it, it was harder to get into and out of gear- like the clutch wasn't working. Even as I slowed down and put the clutch in, it was still in gear and I had to pull the gear shift lever into neutral so that I wouldn't drive through the end of my garage-
I put new 600W oil in (from Birdhaven), took the inspection plate off and sprayed just a little WD40 trying to get the to shaft in case it was gummy. Now it won't go into gear at all when the car is running (just grinds the gears). With inspection plate off, the bearing seems to move back and forth fine with the clutch pedal engaged and off. Tried adjusting the clutch in both directions (clevis) but not better any direction. Did the WD40 screw it up? Any ideas??? Thanks! |
07-29-2012, 02:12 PM | #2 |
Re: Shifting Issue
it sounds like the clutch is stuck to the flywheel or on the trans main shaft, if stuck to the flywheel put car up against a big tree with the trans in high gear and try to get he clutch free up, if stuck to the main shaft you will need to find a way to get some type of lubricant on the shaft
07-29-2012, 02:13 PM | #3 |
Re: Shifting Issue
Check the clutch release arm to see if it is not cracked and separating causing your problem. Brattons sell a steel replacement that is designed to ease clutch pressure by 30% on your leg.
07-29-2012, 02:16 PM | #4 |
Re: Shifting Issue
Sounds like you need a clutch. if its been sitting for a while and the flywheel and pressure plate is rusty you could have ate the cluch up in the first few shifts. than again the clutch disk could be frosen to the input shaft and flywheel. causing you not to be able to shift it . I dought the WD 40 caused any of the problems it woud burned off the clutch and pressure plate first drive you took.
Live your dreams |
07-29-2012, 02:45 PM | #5 |
Re: Shifting Issue
Before you get too nervous,, hold the clutch pedal down, put the monster in gear and rock the car.. You could also jack one rear wheel and drive the car and hit the brakes a few times.. If it comes loose, fine.. It may take a few miles of driving to get all the rust off and start operating smoothly..
07-29-2012, 05:40 PM | #6 |
Re: Shifting Issue
Thanks again!! |
07-29-2012, 06:26 PM | #7 |
Re: Shifting Issue
It shifts but still not shifting all that smoothly. Still acts like the clutch isn't engaging all the way... Maybe more clutch adjustment???????
07-29-2012, 06:44 PM | #8 |
Re: Shifting Issue
How does it shift with the coupe not running. Try greasing the throwout bearing.
07-29-2012, 06:59 PM | #9 |
Re: Shifting Issue
how long have you been driving this car? or Model A's in general?
07-29-2012, 07:17 PM | #10 |
Re: Shifting Issue
Greasing the throwout bearing only greases the shaft it slides on, unless it's an early 28 with a multiple disk clutch.
07-29-2012, 09:11 PM | #11 |
Re: Shifting Issue
This coupe (and a 30 Tudor) were both restored in the mid 80's by my father and me. Since my dad died in '87 and I was off in college and moving from state to state, they sat unused for most of the 30 years except for a few starts here and there by me to try to keep them going.
I just started driving this one again the last month after getting it running after several years of non-use. I already greased the zerk on the throwout bearing. The best lesson: Don't leave them sit! The tudor shifts fine but runs rough (I think manifold gasket has failed and it's sucking air). The Coupe runs much better, but has the shifting issue. It will be nice when they're both going great! My young kids love them. |
07-29-2012, 09:35 PM | #12 |
Re: Shifting Issue
By the way, it shifts fine when not running. Thanks for any additional suggestions!
07-30-2012, 05:55 AM | #13 |
Re: Shifting Issue
I'm not sure what you meant regarding your clutch adjustment.. There should be 1-1.5" of free-play.. Meaning that the clutch pedal should move freely with out any resistance or contact with the release bearing the 1-1.5" ..
07-30-2012, 07:30 AM | #14 |
Re: Shifting Issue
Yes- It is about 1.5 inches now of pedal play. Maybe the clutch is going out...
07-30-2012, 12:15 PM | #15 |
Re: Shifting Issue
Before you get too nervous and start tearing the monster apart,, why not just drive it for awhile.. It'll take time for the clutch assembly to rub away all that rust.. If you feel the need to do something,, just remove the inspection cover and carefully and sparingly add just a bit of oil on the disk and input shaft splines.. This is a good place where less is more..
