Old 07-11-2012, 07:55 AM   #1
cp5491r
cp5491r's Avatar
Default Ammeter discharge with key off
Any ideas why my ammeter shows a strong discharge when I turn off the engine? It shows a strong charge when the car is running. Right now, I'm disconnecting the battery cable when I shut the car off. Later, when I connect the battery cable again, it is normal at zero (not showing discharge) and starts up fine. So the discharge seems short-lived.
Thanks.
cp5491r is offline   Reply With Quote
Old 07-11-2012, 08:09 AM   #2
MrTube
MrTube's Avatar
Default Re: Ammeter discharge with key off
Cutout sticking in closed position?
MrTube is offline   Reply With Quote
Old 07-11-2012, 08:45 AM   #3
PetesPonies
PetesPonies's Avatar
Generator drawing when off? try disconnecting the gen.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 07-11-2012, 08:52 AM   #4
steve s
steve s's Avatar
Next time you shut it down, try giving the cutout a sharp rap with a wrench or something to see if that un-sticks it.
steve s is offline   Reply With Quote
Old 07-11-2012, 09:18 AM   #5
ken ct
I would also agree sounds like a stuck cutout. That will kill the battery in short order. ken ct.
ken ct is offline   Reply With Quote
Old 07-11-2012, 09:30 AM   #6
Mitch//pa
with the car off take a 12v test light
you should only have power on one side of the cut out.. (the side with the wires)
Old 07-11-2012, 09:32 AM   #7
mass A man
mass A man's Avatar
I agree with tapping the cut out when the problem shows up, or a wiring disconnect there if tapping doesn't do it. "BUT" I have had the same problem and found it to be the reproduction ammeter needle sticking!! Tap the ammeter and maybe watch it go back to zero.
mass A man is offline   Reply With Quote
Old 07-11-2012, 01:06 PM   #8
Rainmaker Ron
Rainmaker Ron's Avatar
Thanks.
A sticky cutout is sometimes the first symptom of trouble in the charging circuit. Most liklely there is a poor connection somewhere in the charging circuit...I would check the terminals on the back of the ammeter and also in the terminal box. When the generator "loses" contact with the battery, the generator tries to charge to infinity...probably reaching 20 or 30 volts. This will stick the cutout, blow bulbs, fry coils and burn points. Find and fix the real problem and your cutout will be just fine. You say you are disconnecting the battery cable each time..could be that you are just setting the cable on and there could be the poor connection......Operator trouble.Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 07-11-2012, 01:40 PM   #9
tdlmomowers
tdlmomowers's Avatar
We had the same problem with my Son-in-law's 28 Sedan. Turns out that the Light Switch was grounded. It was a cheap Repo switch. I took the switch apart and cleared the groung in the contact ring.
tdlmomowers is offline   Reply With Quote
