I am having some difficulty identifying the correct PPG paint code for the 1931 Model A Color – Cherokee Gray. I am attaching a chart that I found but do not know if you can see it. I am painting the top of the car French Gray and the color chip code that I researched is 586. According the the local PPG auto paint store it matches the PPG’s code and color. The stripe is going to be Tacome Cream and the code I found is 1245 which also matches the PPG code and color. Cherokee Gray is a different matter. One the color chip chart for 1931 Model A colors the Cherokee Gray is 118 but on the same chart is it 1118, but the chart also lists Seal Brown as code 118. The PPG store has code 118 as Seal Brown and code 1118 as a Peugeot Orange color.
Does anyone know what the PPG color code is for 1931 Cherokee Gray?
Thanks, Mark
