Old 07-11-2010, 10:00 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Overdrive or not???
If a person was to install an overdrive, what would be the best one to consider? Also if you do install an overdrive, what else do you need to do to the A to take advantage of the overdrive?
After having my rig up and running for a couple of months now, I can see if a person wants to go on a lot of long tours, some kind of additional "ump" is needed. But if all you do if go to town for coffee, then the standard rig does it well.
Just thought I would get some comments. Maybe this has been hashed out before on the Barn but thought I would bring it up again.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
