Old 07-11-2010, 08:48 PM   #1
Dave72dt
Default Cam ground pistons
I know current production pistons are cam ground to compesate for heat distortion. Were they always cam ground or originally true round ground? If so, when did that occur?
Dave72dt is offline   Reply With Quote
Old 07-11-2010, 09:12 PM   #2
36fordguy
Default Re: Cam ground pistons
they were always cam ground
36fordguy is offline   Reply With Quote
Old 07-11-2010, 10:47 PM   #3
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
Not all manufacturers used cam ground pistons. It wasn't until the advent of aluminum in piston manufacture that cam grinding became routine. In Cushman engines the cam ground pistons didn't appear until the early 50's. Of course these were air cooled engines and had more radical temperature variations than a liquid cooled automotive engine.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 07-14-2010, 12:36 PM   #4
trainguy
trainguy's Avatar
Many manufactures used split skirt pistons,Ford used them on the Model A.Phil
trainguy is offline   Reply With Quote
Old 07-14-2010, 08:03 PM   #5
Hotrodster
I have a Van Norman piston grinder which I'm sure is from the 1940's, that will grind them either way. I think that is the time frame (40's) when it became common.
Hotrodster is offline   Reply With Quote
