Old 06-24-2012, 07:45 PM   #1
jmeckel
jmeckel's Avatar
Default Extra ground ran to starter
Here is a picture of a cable that I made to add a ground to the starter. It is made from 4 AWG soft copper wire, it is 35" long with single hole connector crimped and soldered (I am a little old school and like electrical connectors soldered and crimped, I have fixed far too many bad connections on communications equipment in emergency vehicles over the years). The cable runs from the frame / battery ground bolt to the bottom bolt on the starter. I ran it along the frame and connected it to the bottom bolt on the starter. It did increase the speed the starter turns the engine over so I did have a ground problem, just did not know it! I was prompted to install this ground after the thread a few weeks ago about the metal gas line getting hot from a bad engine to frame ground.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 06-24-2012, 08:29 PM   #2
Chris H
Chris H's Avatar
Default Re: Extra ground ran to starter
I did the same thing, but used #2 wire, and made it as short as possible. Like you, I crimped and soldered. It made a big difference in the starter's performance. The battery charges better too.
Chris
Chris H is offline   Reply With Quote
Old 06-24-2012, 09:53 PM   #3
tbirdtbird
The ground is so often overlooked in all old cars, just taken for granted. Ya gotta have a complete circuit! No rust or fresh paint in the way! After all a 6V starter draws at least 200 amps. Many modern cars are adopting a dedicated starter ground. And dedicated grounds to all other devices for that matter. I have hidden dedicated grounds to all my Model A lights also. And any electrical connection should be both mechanically strong (crimp) and electrically strong (solder), so I am with you 100 %
'31 180A
tbirdtbird is offline   Reply With Quote
Old 06-24-2012, 10:05 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
If you have a driver, this is the way to go to ensure proper grounding.
Old 06-25-2012, 06:46 AM   #5
Richard Wilson
Richard Wilson's Avatar
Some guys run a 2ond ground wire to the transmission instead of to the starter since it is closer to the original ground location. Either additional ground location might help on a newly painted and assembled car or a rusty neglected one. Headlights are another area that sometime benefit from an extra ground wire also.
Richard Wilson is offline   Reply With Quote
Old 06-25-2012, 06:56 AM   #6
Aerocraft
Aerocraft's Avatar
I have been using a short braided (second) ground strap from where the battery ground attaches to the frame to the left rear transmission cover bolt. By doing it that way, I have only one ground to frame location that I have to keep clean. I do clean that connection annually at the start of the season.
Being very old school, I also solder every crimped connection when I install a new wire harness.
Gar Williams
Aerocraft is offline   Reply With Quote
