Old 06-19-2012, 12:20 AM   #1
pbishop
Default Operating Temp for an 'A'
I changed to a two blade fan this Winter after my four blade spit (cost issue at the time). The car has been running just over 190F in the Florida sun. What is the 'safe top temp' for the 'A'. I am not boiling over, but the temp climbs to just over 200F in traffic stop and go. I am thinking of going to a six blade plastic fan. I here the HP will increase and the cooling is better. Still, I like the original look. One more thing, I cannot seem to locate a neoprene seal for my leak-less water pump.
pbishop is offline   Reply With Quote
Old 06-23-2012, 12:42 PM   #2
cuda
cuda's Avatar
Default Re: Operating Temp for an 'A'
I run a two blade fan and my temp never gets above 180, in Georgia sun. Before I replaced the water pump, it would overheat. I always shut it down and let it cool if it exceeded 225, but I don't know if that's a safe redline or not and I never let it run continuous at that temp. It didn't seem to hurt my motor.
cuda is offline   Reply With Quote
Old 06-23-2012, 12:54 PM   #3
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
I run around 167 to 197 all the time...i have a thermostat installed and run clear water!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-23-2012, 02:28 PM   #4
Milton
Milton's Avatar
Read the thread four blade vs. two blade fan if you haven't already. It says the two blade is the most efficient, for what it's worth. If I read it here I pretty much trust it as having been thoroughly vetted after five additional posts.
As for a safe temp. range, Henry more or less felt under 212° at sea level (most of Florida) was fine. If I used a temp guage I would would be ok with 200° or less. I use a surge tank that is firewall mounted and if it gets hot my nose tells me.
However, if the cooling system isn't clean, then don't try a bandage approach, use a radiator shop that knows Model A cooling systems.
Milton is offline   Reply With Quote
Old 06-23-2012, 02:42 PM   #5
TinCup
TinCup's Avatar
I have found that the ambient outside temps really are a huge factor in cooling. Here in central Oklahoma when the temps are in the mid 80's temps run 160-180 ish. When the creep 90 plus it's veryl hard to keep it below 195 and they can climb to 200 or so in traffic. My 2 blade seems to cool just fine.
TinCup is offline   Reply With Quote
