Old 06-16-2012, 10:09 AM   #1
B-nut
Default clutch installation grease ?
When putting the clutch back together should a thin smear of grease be applied to the throw out bearing face and clutch fingers? Any suggestions? Thanks guys.
B-nut is offline   Reply With Quote
Old 06-16-2012, 10:17 AM   #2
CBoz
CBoz's Avatar
Default Re: clutch installation grease ?
I didn't put any grease on the clutch fingers or bearing face, and only a *very slight film* of high-temp grease on the shaft of the main bearing retainer that the throwout bearing rides on.
CBoz is offline   Reply With Quote
Old 06-16-2012, 04:09 PM   #3
Scott H
Scott H's Avatar
I did very slight film of lubriplate high temp grease on the the shaft, the fingers, and inside the hole.
All of the above pertains to the clutch parts you perverts
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 06-16-2012, 04:27 PM   #4
46ford
46ford's Avatar
Yep I put lithium grease on the clutch fingers and throwout face every time.
46ford is offline   Reply With Quote
