Old 06-15-2012, 04:10 PM   #1
kb
Default 29 hood cowl lacing installation help
Does any one have a picture or diagram of how to correctly bend the end of wire that holds the hood lacing at each end of the gas tank on a 29.
kb is offline   Reply With Quote
Old 06-15-2012, 04:38 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: 29 hood cowl lacing installation help
Do a search for original Cowl Lacing and i think Tom's 28 Phaeton will come up and he has some great shots of it....
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-15-2012, 04:59 PM   #3
wrndln
I bought a special tool from a model T supplier that installs them the proper way. The T tool is used to install some kind of bands (transmission I think) on the model T, but works good for the cowl and shell. The head on the cowl is installed inside and the two prongs are each bent in a arc, not smashed flat. The tool was about $25 plus postage. I might be able to find the supplier if you need it.
Rusty Nelson
wrndln is online now   Reply With Quote
Old 06-15-2012, 06:01 PM   #4
d.j. moordigian
d.j. moordigian's Avatar
www.frankstpartsltd.com
I have no idea why the computer
is doing this....but, kb try this
d.j. moordigian is offline   Reply With Quote
Old 06-15-2012, 06:29 PM   #5
Randy in ca
Randy in ca's Avatar
Here's a picture and diagram I saved awhile back - think it was Tom Wesenberg who originally posted them:
Randy in ca is offline   Reply With Quote
Old 06-15-2012, 06:41 PM   #6
wrndln
The tool I mentioned in my response is the tool Dudley put a link to - Franks parts.
Rusty Nelson
Old 06-16-2012, 12:06 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, that's my unrestored original gas tank lacing. Also note that the wire is fed through the center of the lacing, and NOT over the top of it. Also notice the size of the wire. I've seen some repro wire that is only about half the correct diameter.
Old 06-16-2012, 01:18 PM   #8
kb
Thanks for the pictures they really help.
