Old 06-14-2012, 05:01 PM   #1
wrndln
Default John Deere corn head grease
Has anyone used corn head grease in the steering box of a model A? I am having trouble with minor leaks at the bottom of my 7 tooth column I just rebuilt. First I didn't use any sealer, like was advised here by a couple of Fordbarner, but it leaked. I used Permatex to seal the shims and threads on the bottom bolts, but one bolt has a slow leak - I don't know why. I was thinking of using corn head grease, as it is supposed to not leak and lubs well. I pasted in a link to a YouTube video about the grease. It sound great and is only about $4 a 11 oz tube. If anyone has used corn head grease in a steering column, please let me know how it worked.
Rusty Nelson
https://www.youtube.com/watch?v=UEwk_sYP6A8
Old 06-14-2012, 05:19 PM   #2
bogdonj
bogdonj's Avatar
Default Re: John Deere corn head grease
I only use corn head grease on my U Joint.. not sure if it should go in the steering box. You may have to heat it up to get it in if you do..
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 06-14-2012, 05:20 PM   #3
Ian NZ
Ian NZ's Avatar
I am using John Deere Cornhead grease in the steering box of my 1932 Ford and it is working well, no leaks as yet. I had a bit of a Job removing the 600W oil from the steering box with a suction gun and a thin plastic hose though. It was easy to fill the steering box with the Corn head grease as I just poured it out of the cartridge into the steering box as it was just like extra thick oil, you do not have to use a grease gun.
Ian NZ is offline   Reply With Quote
Old 06-14-2012, 05:46 PM   #4
Bill Lee/Virginia
Has anyone used this grease in the transmission or differential of a Model A Ford? What is your experience? Good? or Bad?
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 06-14-2012, 07:53 PM   #5
glenn in camino
glenn in camino's Avatar
I mix 600W with grease to make the 600W thicker but so it will still flow. Leaks a little but not very much. I have those aftermarket tubes and straight 600W in a couple of my cars. They work really good.
glenn in camino is offline   Reply With Quote
Old 06-14-2012, 10:11 PM   #6
jfrankhash
jfrankhash's Avatar
Haven't tried it in the Miss Frances (1930 ccpu), but it is a well known steering gear fix for Farmall Letter series tractors from the 40's and 50's.
jfrankhash is offline   Reply With Quote
Old 06-14-2012, 10:49 PM   #7
1931 flamingo
1931 flamingo's Avatar
Penn-Rite steering box lube, comes in a bottle. Available from Restoration Supply, Escondida, CA. They have an online catalog. About $14 plus shipping. I put in 600w and it all leaked out. Put Penn-Rite in and NO leaks in over a year. JMO
Paul in CT
Old 06-15-2012, 08:44 AM   #8
Chris in WNC
Chris in WNC's Avatar
use STP- it leaks out slower than gear oil.......
with corn head grease or any other grease you will eliminate most leaks but also eliminate most lubrication of the steering gears......
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 06-15-2012, 08:58 AM   #9
jmaotto
Cornhead grease works well in my Ford 8N tractor.
jmaotto is offline   Reply With Quote
Old 06-15-2012, 10:43 AM   #10
CarlG
CarlG's Avatar
OK, So IF, and that's a big IF, I were to decide to put the corn head grease in my U-joint, would I have to clean out all the other stuff in there, or just begin adding it as needed. It currently has that Mystic jt6 in it right now, but I need to add more, I'm sure. (I'm sure there's not a full tube in there)
Old 06-15-2012, 12:21 PM   #11
wrndln
CarlG,
Does your U joint leak? If it doesn't, I would keep using Mystic JT6. If JT6 is leaking, I am not sure corn head grease wouldn't leak also, as JT6 is very thick compared to gear oil. I was concerned about the steering column with Mobil 680 gear oil in it with a very slow leak. I hate leaks! It is the only thing that leaks on my newly assembled chassis (so far anyway). I think corn head grease would work pretty well in the transmission and differential as well as the steering box after seeing the YouTube video. I just checked with a local John Deere dealer and they have corn head grease for about $3.50 an 11oz tube - not to bad.
Rusty Nelson
Old 06-15-2012, 12:26 PM   #12
d.j. moordigian
d.j. moordigian's Avatar
Rusty,
I liked the YouTube video.....is that stuff EP?
d.j. moordigian is offline   Reply With Quote
Old 07-10-2012, 01:51 PM   #13
Rebel Sympathy
You do not eliminate lubrication with corn head grease. While it is a grease, it is continously in a state of flux; turn the wheel and the grease settlles back into the air pocket created by the movement of the worm and sector. It works great. I have used it for years. In one instance the leak was so bad that the corn head grease still oozed out over time. Other than that, it has been great.
Mike
"There is no 'normal life'; there's just life." - Doc Holliday from the film Tombstone
Rebel Sympathy is offline   Reply With Quote
Old 07-10-2012, 02:44 PM   #14
Seth Swoboda
Seth Swoboda's Avatar
I recently put some John Deere multi-lube in the steering box of my 39 pickup with good results.
Seth Swoboda is offline   Reply With Quote
Old 07-10-2012, 02:58 PM   #15
MrTube
MrTube's Avatar
Ah, the old "my steering box leaks so I drained the oil out and put grease in" discussion.
I have to ask, if this is the logic being used, do you do the same when your oil pan or rear main leak? Drain the oil out and pump grease in? Is this the solution to an oil leak on a device engineered to use oil?
MrTube is offline   Reply With Quote
Old 07-10-2012, 05:29 PM   #16
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
MrTube, you have been a member of this forum long enough to know that alot of people would rather find a quick fix then a proper one.
Old 07-10-2012, 05:40 PM   #17
d.j. moordigian
Uhhh....
1. band-aid
2. cranky
3. put a diaper on it
Old 07-11-2012, 08:24 AM   #18
spdway1
spdway1's Avatar
I shower with it and it slows hair loss!
I would fix it the correct way!
spdway1 is offline   Reply With Quote
Old 07-11-2012, 09:38 AM   #19
Hunter
Rusty,
If it makes you fell any better I have gone through the same process as you and still have a very small leak (using 600W). I plan to take the column out and address it this winter. At least you were wise enough to test/fix the isuue before you installed the column in the car which is what I did
Hunter is offline   Reply With Quote
Old 07-11-2012, 03:51 PM   #20
wrndln
Hunter,
I think I have the problem with the leaky bottom bolts fixed. It was a very easy solution and didn't require the column to be removed. At least it hasn't leaked for two weeks and running. Earlier I had put Permatex #2 on the surfaces of all the shims, the bottom plug and all the bolt threads and side plate. The very minor leaking was from the two bottom bolts. I removed the bottom bolts that were leaking and wrapped about 12 to 15 rounds of heavy cotton thread around the bolt just under the head. I then slid on the lock washer and then wrapped around the same amount of thread below the lock washer. I put some Permatex on the thread wrappings and reinstalled the bolts. I did this to both the bottom bolts as they were the only spots the oil was coming from. I was going to use cornhead grease, by maybe now I wont have to. If it starts leaking, next will be cornhead grease in the steering box.
Rusty
