05-23-2012, 07:46 PM | #1 |
waterpunp bolt
Anybody have a pro or con on useing s/s bolts for inside pump to block?
Thanks, Em |
05-23-2012, 08:04 PM | #2 |
Re: waterpunp bolt
I have had no problems doing it this way. Remove my pumps after 10 years in service had no problems removing s/s bolts.
05-23-2012, 09:05 PM | #3 |
Re: waterpunp bolt
I use SS on my builds ...
Vergil
Bigger fonts to aid in reading |
05-23-2012, 09:34 PM | #4 |
Re: waterpunp bolt
I consider it a neccessity just make sure you use an anti-seize on the bolt. See you at Lancaster show.
"Never complain,never explain"... Henry Ford II |
05-24-2012, 06:08 AM | #5 |
Re: waterpunp bolt
I agree with all of the above, I use SS bolts on all the water pumps on our Flatheads. Like 37 Coupe says, make sure you use anti-seize on the SS bolts.
05-24-2012, 07:24 AM | #6 |
Re: waterpunp bolt
www.fordcollector.com |
05-24-2012, 07:45 AM | #7 |
Re: waterpunp bolt
SS with anti seize on threads is the way to go for that one internal water pump bolt. It can be a real pita removing a plain steel bolt that has broken off inside the block. Also dealing with a plain steel bolt that has most of its hex head rusted away can also make you say some very bad words
05-24-2012, 08:16 AM | #8 |
Re: waterpunp bolt
Thanks everyone for your advice. S/S it is! 37coupe, I plan on being there.
Thanks, Em |
