04-19-2012, 03:58 PM | #1 |
Flathead road test......
Had a chance to test our record attempt 1949 Ford Truck with flathead.
Truck will run the ECTA XF/PP flatheadx /production pickup class next week in Willmington Ohio. Our gps shows 104 mph ( good enough) . |
04-19-2012, 04:02 PM | #2 |
Re: Flathead road test......
That's very interisting Babba, can you tell us whats in the engine or is it a secret? Walt
04-19-2012, 04:08 PM | #3 |
Can do later Walt i am trying to get the video to play . Will work on it later tonight......
04-19-2012, 06:18 PM | #4 |
04-19-2012, 06:27 PM | #5 | |
Walt , Theres more info at www.gasolinealleyshops.org We built this truck as a group of guys for Bonneville. Three to four different shops and approx 15 people . The engine is a 279 cu in flathead, snyder camshaft,offy heads , offy intake , 600 holley four barrel and a vertex magneto. Rear axle is a nine inch ford with a 3.73 third member and a five speed transmission. We ran 96.7 mph in 2006 at Bonneville and took a real lesson on Utah air and elevation. We have since found 40 more hp and today was the first interstate ride before the ECTA meet. We do plan a day on a chassis dyno for some air fuel and timing adjustments before leaving next friday morning for the Ohio meet. Our run today was in fourth gear ( 1/1) and we ran the GPS up to 104 mph.. Fifth gear would only run 88 mph.....overdriven at .63 od... |
04-19-2012, 07:02 PM | #6 |
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
04-19-2012, 09:04 PM | #7 |
Yes, best of luck. That was the same record we were after at Bonneville back in 07. I think
04-19-2012, 10:12 PM | #8 |
Jim did you point us to your fb page so we could see it was your birthday? Okay happy birthday Jim .... wish I could find another 40 or 50 hp in my flathead, good job and may everything click when running hard .........
Bigger fonts to aid in reading |
04-20-2012, 07:17 AM | #9 | |
We do use facebook pages at the shop and post there every day or so as well as bubbas hot rod shop and linder fuel injection... |
04-20-2012, 09:24 AM | #10 |
I had one the other day, but I've had so many, I just watch em pass and look forward to another.
04-20-2012, 11:32 PM | #11 |
Well happy Birthday guys!
Building a 29 Sedan on 32 chassis........ very slowly.... |
