Old 04-13-2012, 03:37 PM   #1
Steve Plucker
Default Head torque sequence?....
How was it decided on just what the head torque sequence was to be? Not only Modle A but other heads also?
Interesting.
Pluck
Old 04-13-2012, 03:57 PM   #2
Charlie Stephens
Default Re: Head torque sequence?....
You want to start in the center and "iron out" the wrinkles in a circular pattern as you go towards the edges. You dont want to lock down the edges and then move to the center.
Charlie
Old 04-13-2012, 04:45 PM   #3
Kohnke Rebabbitting
Here is what we use.
File Type: jpg Dave's Model A from Lincoln, Ne , Part 2 001.jpg (33.6 KB, 107 views)
Kohnke Rebabbitting is offline   Reply With Quote
Old 04-13-2012, 05:11 PM   #4
John Stone
John Stone's Avatar
Here is what I use:
John Stone is offline   Reply With Quote
Old 04-13-2012, 07:40 PM   #5
400A-64
400A-64's Avatar
Charlie...My shop teacher waaaay back in the late 40's and early 50's said the same... If you donot have the factory plan...start in the center and work your way out!!
Bruce Davis [email protected]
400A-64 is offline   Reply With Quote
Old 04-13-2012, 09:22 PM   #6
Jamie86
Have you been using this torque sequence for a while with no problems ?
Jamie86 is offline   Reply With Quote
Old 04-13-2012, 10:06 PM   #7
ratamahata
ratamahata's Avatar
This
ratamahata is offline   Reply With Quote
Old 04-13-2012, 10:31 PM   #8
Kohnke Rebabbitting
52 years! Model T's, A's, and B's.
Old 04-14-2012, 01:05 PM   #9
rollingsculpture
rollingsculpture's Avatar
very interesting how each of the four sequences produce a different geometric pattern shape which produces pressure in a corresponding shape for instance the sequence provided by john stone is a spiral pattern wheras the kohnke sequence is a line axis pattern that is based on the pressure applied from the line center front to back than cris crossed as an x pattern the ford one on ford garage is more of a spherical centered shape that places all pressure in the middle of the block first than tightens out the front of block than the rear . fun puzzle . thanks
Rust and roll will never die
rollingsculpture is offline   Reply With Quote
Old 04-14-2012, 01:25 PM   #10
Greg way out West
Exclamation Re: Head torque sequence?....
Hi Steve,
I changed the torque pattern so I do the 2 water outlet nut's together...Why Ford used the outlet for head Torque is beyond me ?. Didn't use it on the "T's" or "B's"...Also just a "Tip" about the outlet..
Don't use the paper gasket for the water outlet...nor the match trick..Use no gasket with sealer or the Copper "original" type with the crush ring's....
Greg out West
Greg way out West is offline   Reply With Quote
