06-29-2010, 04:23 PM | #1 |
Kingpins
Looking into changing king pins on our A.
I'm a bit confused as to the process. Do only the pins wear, or do both the pins as well as where they ride in wear? My assumption is you buy oversized pins and machine or ream where they get pressed in to. My other question is I just spent a while looking in the Bratton catalog and could not find any trace of king pins, is there another name for them? |
06-29-2010, 04:33 PM | #2 |
Re: Kingpins
The heaviest area of wear is usually the bushings in the spindles. If you are doing it yourself, you are going to need a bushing reamer for the spindles. They pop up on ebay fairly often. Just be sure to get the right size. (.812) Be careful of some reamers that parts houses sell that seem to be a little oversize and then you have loose kingpins again.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 06-29-2010 at 04:40 PM. |
06-29-2010, 04:33 PM | #3 |
Re: Kingpins
The king pins supplied are only of one diameter. It is the bushings of the spindles that wear. New bushings must be pressed into the spindles, and the spindles with the new bushings installed must be "pin hole honed" on a shop machine (preferred) or reamed using the proper sized parallel king pin reamer.
06-29-2010, 04:43 PM | #4 |
Re: Kingpins
06-29-2010, 04:43 PM | #5 |
Re: Kingpins
Ah I see.
I found several things including kits in the Bratton's catalog. Looks pretty straight forward. However I noticed all of them say to ream to .814. Bratton's also has a .814 reamer. If I buy these bushings, reamer, and pins from them would it all work out? I would assume the pins Bratton's have match the rest of the kit? |
06-29-2010, 04:49 PM | #6 |
Re: Kingpins
Dick Spadaro sells the correct reamer. http://www.dickspadaro.com/king_pin_reamer.htm However, you can find old tools on eBay from the 30s - 50s for much less. I think I paid something like $30-40 for my old Ford reamer. Works like a champ with a vice and a wrench and a little 3 in 1 oil to keep things smooth. I would bet that you could get away with just buying the spindle bushings and re-using your kingpins and bearing if it's ok.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
06-29-2010, 04:54 PM | #7 |
Re: Kingpins
.814 is fine, and Bratton's has good stuff. It will all go together. The key thing, is the two spindle bushings need be perfectly alligned to each other. The reamer needs to reach the second bushing to allign with the first when reaming. It's not rocket science. Some swear by having a machine shop hone them, claiming greater accuracy. Likely, the cost of the reamer will pay for the job in a machine shop. Some front end shops use the wrong reamer, too short, and being .001 off will cause binding.
06-29-2010, 04:58 PM | #8 |
Re: Kingpins
Russ is correct that your reamer end MUST reach the second bushing before the main flutes start reaming the first bushing, so you need one with a longer end. I also agree that for the price of a shop doing it for you, you can own the tool and do it yourself again, and also on your friends cars.
06-29-2010, 05:00 PM | #9 |
Re: Kingpins
Simultaneous posts Elrod!
06-29-2010, 05:07 PM | #10 |
Re: Kingpins
I know. I was agreeing with you. Hence the "Russ is correct that..."
Glen C posted the same thing I did in my first post, but that is fine with me. Repetition is good for learning. Mr Tube. I sent you some eBay auctions to look at in your Private Messages box.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 06-29-2010 at 05:13 PM. |
06-29-2010, 07:12 PM | #11 |
Re: Kingpins
The answer is you must first take your king pins out and measure them.
They could be loose just from poor fit or reamed bushings. Check your axle ends for snug fit. If the kingpin has some serous movement in the end of the axle then your axle is bad. Once you press in the new bushings you are better off having a machine shop align hone the bushings to size. Reaming works, but will always leave high spots as they do not do a perfect cut. These high spots will hold the kingpin tight at first, but quickly wear to leave a couple of thou of looseness. If they are align honed then they will be round with no high spots and will stay tight much longer. If you go with the repro kingpins and you have repro brake pins then make sure you do not have any binding action. I found that there was some slight binding with my NOS kingpins and a repro brake pin I test fit. I have heard that the repro kingpins do not have the best holes in the center for the pin, but have not confirmed this. It is wise to check all the fits anyway. BTW, while you have the car this far apart, are your front brake wedges known to be good and equal or just good used? I ask because I believe this is a potential problem area the can be overlooked. The common recommendation is to just file the front wedge smooth and use them. The problem is you can end up with different wedges from side to side. This may give you a problem that is not something you can adjust out. The repro wedges are pretty good and a matched pair might be a good thing. |
06-29-2010, 08:26 PM | #12 |
Re: Kingpins
Using the reamer was one of the mistakes I made, the reamed bushings are loose, they were loose by 10,000 miles, on my 46 I honed them, they were still tight as when I first did them at 25.000 miles.
06-29-2010, 10:16 PM | #13 |
Re: Kingpins
A company I worked for in my youth sent all bushing install
work to a machine shop who burnished all bushings after pressing them in, and then did the reaming and the final honing. Over kill perhaps, but never a kickback from our customers. |
07-01-2010, 12:08 AM | #14 |
Re: Kingpins
Kevin in NJ is right on the money! Also, micrometer check the diameter of the kingpin for #1. roundness, #2. undersize, and #3. taper. They must come in at .812" in all three catagories. If not, send them back - they are not worth installing. Demand the correct dimension pins. They happen to be the same price as the bogus pins.
How do I know? I have encountered undersized and tapered new repro-ed pins. |
07-01-2010, 06:21 AM | #15 |
Banned
Re: Kingpins
skip. Nothing to it. We did a King Pin change for the club's Spring Clinic in less than four hours and a couple dozen donuts and cups of coffee. . Again. Hold control key down and poke the + key to enlarge the print so tired eyes can see it. Or print it. |
07-01-2010, 07:14 AM | #16 |
Re: Kingpins
Honing is the way to go. You get a sliding fit on the pin.
07-01-2010, 04:12 PM | #17 |
Re: Kingpins
The bushings in the spindles wear first then the pins. Sometimes you can replace the bushings and ream to .814 if the pins are not worn. mostly you will need to replace both. I have never heard of oversize king pins. I would check with Berts in Denver, They are experts and may have new old stock king pins,
I got my king pin reamer from Bratton in the early ninties. |
12-15-2016, 08:49 PM | #18 |
Re: Kingpins
When I bought the kingpins for my car in the late 90's, the new ones had a slightly triangular shape. I could feel it with my fingers when I twisted them with the other hand. I also used a reamer which besides being slightly over size did not make a perfectly round hole. Turning the king pin in the spindle had slightly tight and loose positions. There is about 1/4" movement in and out on the top of the tread.
I am in the process of replacing mine with NOS TRW kingpins and having the bushings honed to size. Also going to replace the steering arms with rebuilt ones with new balls and replacing the teflon seats.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
12-15-2016, 09:14 PM | #19 |
Re: Kingpins
I'm currently entirely rebuilding the front axle on my car. I had not yet gotten to the kingpins but I'm beginning to sway towards having a machine shop machine my bushings as opposed to using the reamer my club has.
12-15-2016, 09:18 PM | #20 |
Re: Kingpins
Thats what i do. Sunnen hone
