Old 03-10-2012, 09:03 AM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default New Radius (wishbone) Arm
Finally found a radius arm to replace the old one. Painted all the parts as I cleaned them, and I am now putting everything back together. Now it seems that the water pump decided to start leaking at the adjustable nut. I tightened it but still drips. Is there a packing I can put in, or does it just need to be rebuilt? Also, the old radius arm had the rubber ball. Should I replace the ball or just use the washer if needed. I believe this is what controls the castor measurements, and maybe I don’t even need the washer at all. What say all you?
Thanks, Tom
Tom Cavallaro is offline   Reply With Quote
