Old 02-29-2012, 06:15 PM   #1
mll1446
Default Mitchell overdrive help
Anyone have any information or instructions how to operate Mitchell overdrive . Thanks
mll1446 is offline   Reply With Quote
Old 02-29-2012, 06:19 PM   #2
CarlG
CarlG's Avatar
Default Re: Mitchell overdrive help
TRANSMISSIONS
Mitchell Manufacturing (800) 859-2088 (California) [email protected]
Old 02-29-2012, 06:24 PM   #3
Bruce in southern OH
Bruce in southern OH's Avatar
You can operate at least two ways, 1st, 2nd, 3rd and then shift lever to Overdrive.
Second method is to make a 6 speed out of it, (like a big truck ) 1 low, 1high, 2low,2high,3low, 3high
Push in clutch and shift, Bruce
Bruce in southern OH is offline   Reply With Quote
Old 02-29-2012, 06:55 PM   #4
Joop
Joop's Avatar
From Mitchell Instruction sheet
Click on picture 2 times to get the "BIG" picture.
Joop is offline   Reply With Quote
Old 02-29-2012, 07:25 PM   #5
John LaVoy
John LaVoy's Avatar
Is the question because it is not working?
John LaVoy is offline   Reply With Quote
Old 02-29-2012, 08:53 PM   #6
mll1446
No nought car with one in it don't know how to work it
Old 02-29-2012, 11:40 PM   #7
John LaVoy
John LaVoy's Avatar
ON the knob it says high and low if I remember correctly. I have a cable version and pulled out it is out of over drive and that would correspond to the lever pulled back. With the lever shoved forward you would be in overdrive. You need to push in the clutch when making the shifts. It would be wise to check the fluid level in the box mounted on the torque tube. Small hole on the side about half way up. Uses and allen wrench to check it. I use mine as an overdrive get up to about 40+ and shift it into overdrive.
Hope that helps.
Old 03-11-2012, 09:15 AM   #8
Joop
Joop's Avatar
Did you get it in overdrive?
