Old 02-28-2012, 10:30 PM   #1
allen
allen's Avatar
Send a message via ICQ to allen
Default Rebuilding oil pump
just got my oil pump rebuild kit, from Bert's install the bushing then install the new shaft and idle gear only to find out it locks up turning hard turn the idle gear both ways still hard to turn, by it self each gear turns easy when install together there is binding anyone had this happen to them AL
allen is offline   Reply With Quote
Old 02-28-2012, 10:41 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Rebuilding oil pump
Did you ream the bushings or burnish them in after installation?
I'm wondering if the ends didn't get a bit deformed while installing them.
On second though I see where you say they turn easily by themselves. Do they turn hard with the bottom plate installed or also with it not installed?
Old 02-28-2012, 11:20 PM   #3
allen
allen's Avatar
Thanks tom for the reply yes the bushing are smooth the shaft by itself turn easy very nice its when you add the idle gear that there is a issue
Old 02-29-2012, 02:43 AM   #4
ctlikon0712
ctlikon0712's Avatar
Then it is an alignment issue. Perhaps they didn't align exactly when they pressed in..... Perhaps a reamer by hand would clean it up.... Have you ever used one? Please don't be insulted by my asking that question.
ctlikon0712 is offline   Reply With Quote
Old 02-29-2012, 07:57 AM   #5
allen
allen's Avatar
Thanks for the reply and yes I use reamers before thanks for asking, It seems to me that it is a meshing problem the shaft itself with the gear on it is very smooth turns easy there is no slop in the brass bushing and the shaft, if you take this shaft out then just install the idle gear it also very smooth no drag, if you install both of them this is were you get the drag i did not have to ream the bushing the shaft went right in. Does the main shaft need to have play thanks Allen
Old 02-29-2012, 08:51 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
If it just bindsup in 1 or 2 spots look for dings and burrs on the gear teeth ---mark the teeth that bind together and look close
Old 02-29-2012, 08:54 AM   #7
1931 flamingo
1931 flamingo's Avatar
Are these new gears or the old ones. If new, do you have the old ones to try??
Paul in CT
Old 02-29-2012, 09:47 AM   #8
allen
allen's Avatar
Paul in CT
OK got up this morning went and install the old idle gear with the new shaft perfect smooth as glass, install new one blinds up got to be in the new gears,
Old 02-29-2012, 09:58 AM   #9
John Stone
John Stone's Avatar
I have run into this problem with the cheaper rebuild kits. Never with the melling. You just have to put something on the gear to find the high spots and file them off. I have used prussion blue and just magic marker.
John Stone is offline   Reply With Quote
Old 02-29-2012, 12:22 PM   #10
Kohnke Rebabbitting
Your Right John, Melling is the only kit to use, they made kits for the Model A when they were new. The Repro kit does not fit, and the one I had, had chatter markes on the gears, and the bushing were oilight, I Think? very poor! Herm.
P.S. Melling Kit No. K-18
Kohnke Rebabbitting is offline   Reply With Quote
Old 02-29-2012, 12:34 PM   #11
Clem Clement
Clem Clement's Avatar
Did you try turning one gear over?
Clem Clement is offline   Reply With Quote
Old 02-29-2012, 12:40 PM   #12
Wuudie
Wuudie's Avatar
Thought this too test see what happens.
Wuudie is offline   Reply With Quote
Old 02-29-2012, 12:43 PM   #13
allen
allen's Avatar
yes Clem every which way as i said you can install the old idle gear and it works fine, called Bert's and He said he will refund, where do you get melling who has it
Old 02-29-2012, 12:45 PM   #14
1930artdeco
1930artdeco's Avatar
I looked up the melling site and I find a price on the kit or how to order one. Anyone have an idea?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-29-2012, 01:13 PM   #15
Kohnke Rebabbitting
Mike
Any auto store, that handles Melling brand, try N.A.P.A.? Herm.
Old 02-29-2012, 01:20 PM   #16
Ron/IA
I found one dealer - Northern Auto Parts
http://www.northernautoparts.com/Pro...ntoryId=440431
This address should take you to the kit they sell
Ron/IA
Note - I looked on the NAPA & Carquest web sites and they did not carry the oil pump kit amoung their on-line listing. It may be worth while to call your local car parts store and check.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 02-29-2012, 10:50 PM   #17
allen
allen's Avatar
Ron/IA
Thanks Ron and all you guys as always best place to find answers. thanks. I order the melling k18 will post update when i get it in AL
