Old 02-25-2012, 08:36 PM   #1
BCCHOPIT
BCCHOPIT's Avatar
Default Mystery Water Pump
Hey Guys...
I found this water pump on my 31 Tudor to day. The housing is not like the others I have.
you can see there is a big slot cast in to the housing
Thanks for any input
Bill
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 02-25-2012, 10:00 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Mystery Water Pump
Could it be from a Gleener combine?
Whar color were Model A engine used on a Gleener?
Old 02-26-2012, 07:34 AM   #3
BCCHOPIT
BCCHOPIT's Avatar
I bolted it back up to the head and the flange is a little
wider then where it sits on he head.
Old 02-26-2012, 11:36 PM   #4
columbiA
Just looks like an after-market one similar to the original.Some have a cylindrical hsg that covers the entire shaft.
columbiA is offline   Reply With Quote
Old 02-27-2012, 01:17 AM   #5
Rowdy
I have an aluminum one simular in design. Definately aftermartket. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-29-2012, 10:05 PM   #6
BCCHOPIT
BCCHOPIT's Avatar
Thanks guys
It works so I will use it
