Old 02-25-2012, 09:52 AM   #1
Wuudie
Wuudie's Avatar
Default frame question
Are all years frames interchangable? Can you use a 30 frame with a 29 body or visa versa or maybe a 28 frame for a 31 body? I know there's a difference in the cross member where Rad mounts- but are there any other significant differences that one would have to take into consideration? Body bolt mounts all the same? Just a curiosity question
Wuudie is offline   Reply With Quote
Old 02-25-2012, 10:18 AM   #2
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
Default Re: frame question
There was a thread on here just the other day addresing all your questions.....Dave,...Very informative
85930tudor is offline   Reply With Quote
Old 02-25-2012, 10:32 AM   #3
Kevin in NJ
The answer is at Steves website:
Steve Plucker's research
In a nutshell they are interchangable, BUT
There are some differences and adjustments you need to handle different situations.
Read Steve's research and then ask further questions.
Kevin in NJ is offline   Reply With Quote
Old 02-25-2012, 10:47 AM   #4
Mikeinnj
Mikeinnj's Avatar
Wuddie,
In short , and a direct answer is that you can use any year frame with any year and model body, however some changes must be made to the frame. The 28-29 frame's front x-member provides a taller mounting for the radiator. That front x-member was changed for 30-31 and has a lower mounting area for the radiator. Also different model body styles required different mounting brackets. So yes, by adding and changing x-members, and brackets, frames can be mis-matched. Will the car be "Judging Standards" correct ? No, but that may not matter to you.
Mikeinnj is offline   Reply With Quote
