Old 02-20-2012, 02:12 PM   #1
Pilotdave
Pilotdave's Avatar
Default Axle Play at Hub End
Latest questions in the brake rebuild saga! Would appreciate some input on the following:
1. With left rear hub off the car, I can move the end of the axle up/down or side/side about 1/8". I am not talking about play in/out of the differential housing. Also, I haven't (yet) pulled the right rear drum to check for similar play. Checking the books, I see no bearing indicated inside the axle housing at the hub end, so a worn bearing at that spot is not allowing this movement.
What amount of movement is normal? If 1/8" is excessive, what problems can this cause?
2. There's a grease fitting on the axle housing inboard of the plate to which the backing plate mounts. What is lubed via this fitting?
Thanks much! And here I thought I could assemble the left rear corner all on my own.
Pilotdave is offline   Reply With Quote
