#1 |
I know you can do it, my question is how? I have two sets of original Ford 3.54 (39-11) gears from a 35-36 rear end, and I want to put them each in my 33 pickup and my 34 roadster. Both are the late 33-34 rear ends with the "star" shaped end on the torque tube. What is the difference, and what does it take to make them work? Any help would be great!
Thee Inland Emperors |
#2 |
I know I have one, maybe two written procedures on how to put the later gears in the earlier rears, saved in my computer files. I can't access those files right now because I only have my smart phone and I can't access those files on this phone. I believe one procedure was written by Richard Lacy and posted here some time ago. Have you possibly checked in the archived files here to see if you could find any information there? Unless somebody else posts it first, I could send this to you tomorrow. Send me a pm with your email address if you would like me to send you a copy tomorrow.
Cheers...
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-19-2012 at 11:08 PM. |
#3 |
I did the exact same thing on my 34 pickup. This is from memory which is fading rapidly.......
1. The biggest issue is the fact that the 35/36 pinion is too large to go into the casing. The pinion must be turned down to fit into the earlier bearing housing and using the 33/34 bearings. 2. The pinion gear won't fit thru the opening and must be ground to give enough clearance. 3. Some of the ring gears are too wide and will hit against the axle housing. Notice that the 33/34 has a step on the back side where the 35/36 doesn't. I ground a little off of mine in that area, I think around .020". 4. The later pinion is 1/2" longer than the early one. You will have to shorten the driveshaft. I think thats it........... If anybody has a 3.54 gear set for sale I'm looking for one. |
#4 |
You'll have to machine the o.d. of the pinion gear teeth down so they'll fit through the hole in the banjo to install the pinion gear assembly. If your gears are the '35-36 with a 10 spline pinion, you'll have to shorten your '34 driveshaft by 1/2" and install a 1/2" spacer over the pinion and between the front pinion bearing and the pinion nuts. If your later gears are the '37 and up with a 6 spline pinion, then you'll have to machine a 6-10 spline adaptor to replace the 10 spline coupler in the driveshaft to wind up with 6 spline at the pinion gear end. Sometimes, you have to take a little off of the o.d. of the ring gear teeth for clearance on the i.d. of the banjo, but not always. Unless I forgot something, that's it. I can't remember if the pinion gear front bearing surfaces require machining or not, you'll just have to measure and compare to the bearing i.d.
#5 |
Thanks a lot guys! More to it then I thought but not that complicated.
#6 |
#7 |
On a side note, I have a 33-34 rearend that someone put a 35-36 3.54 banjo in. Rather than swap the gears, they swapped in the whole banjo. They had to shim the carrier bearings to make up for the 1/4" difference in banjo width. I am not sure what they did for axles...
Neal |
#8 |
Here is some info someone posted on the Hamb for me:
#9 | |
![]() Quote:
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
#10 | |
![]() Quote:
Yeah, got anymore light to shed Neil?
#11 |
Interesting post by Chris in WA, above... at least interesting to me. There are a whole bunch of words there that I recognize, as I penned them, many moons ago. Of course, along the way, it has received some 'polishing', editing, correcting, and additions. How it ever got to the hamb, ??? And, who did the polishing, editing, correcting, etc ??
On Neal's post... usually the 35-41-style axles, with mods posted by rumbleseat Paul. Not a conversion that most of us should consider. IMO To Jason, on the same post... I wouldn't recommend it. However, read what rumbleseat did, and decide for yourself. (tech site -- billB) JMO |
#12 | |
![]() Quote:
I duuno BobH, I just coppied and pasted what was posted on the Hamb board. Good info though!
#13 |
Some parts of that same write up appear to be the work of Richard Lacy as well. I believe a 'hamber' probably copied most all of that info here on FB and reposted it over there for you. I guess it really doesn't matter that much as long as the 'fine tuning' is still accurate information.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-20-2012 at 11:21 PM. |
#14 |
believe there's also a couple of older V8 Times articles on pinion & ring gear late.....to early exchange. i'll have to find the year and month. one was written by Ken Showers.
1940 Mercury Looking for DENVER heads - 81AS - 99AS - 19AS |
#15 |
33-34 axles are too short if you use 35-48 banjo.Use 35-38,18 tooth axles & 12 tooth spiders or the 39-41 16 tooth axles & 11 tooth spiders. Vol 38 # 2,page 17-18 of theV8 TIMES has the article on fitting 35-48 ring & pinion in late 32-34 banjo.
#16 |
[QUOTE=columbiA;369973]33-34 axles are too short if you use 35-48 banjo.Use 35-38,18 tooth axles & 12 tooth spiders or the 39-41 16 tooth axles & 11 tooth spiders. Vol 38 # 2,page 17-18 of theV8 TIMES has the article on fitting 35-48 ring & pinion in late 32-34 banjo.[/QUOTE]
Could you please take a copy of that article and put it in here so we all can read the article. Or is there another way to read the article? / Jorgen |
#17 |
There is no 32-34 banjo center with later axles and bells that work without machining
soloution. You can use a 35-48 center and axles, 33-34 bells and remachine the axles cone so drums will be back in their original position I would machine the 35-36 10 spline 3.54 pinion that the early pinion bearings fit. Then it is a bolt in deal No rework of the driveshaft etc. I like simple soloutions... Michael |
#18 |
Michael, I agree with you!
But as someone said, You will get many answers here! Then you have to sort them out to suit you best. / Jorgen |
#19 |
Except that the '35-'36 pinion will still be 1/2 inch too long, requiring shortening the driveshaft 1/2 inch OR sliding the driveshaft back on the pinion gear 1/2 inch and redrilling the hole, also requiring trimming the back of the 10 spline coupler on the driveshaft to allow it to slide back on the pinion that far. Turning the pinion teeth down to fit into the '34 banjo and then the machine work on the front pinion bearing surface would still be required.
The reason for the 1/2 of additional pinion length, is that Ford extended the torque tube flange 1/2 inch forward from the '34 and earlier dimension, on the '35-'48 banjo center sections, so the '35 and later pinion gears are also 1/2 inch longer. Last edited by Randy; 02-26-2012 at 11:16 AM. |
#20 |
Could you simply slide the driveline back a 1/2" and re drill the hole? Even if you had to cut a little bit off the back of the driveline. Or cut 1/2" off the front of the pinion splines and redrill the hole...just thinking out loud
