Old 01-27-2012, 12:53 AM   #1
Peter J
Peter J's Avatar
Default B dist.timing
Hey Guys,
Simple question I hope, but what's the difference between the rotor position when setting the timing between and A and completely stock B engine. Vince Falters site describes timing a B but with a Petrox (sp) setup rather than points. Centering the rotor on #1 dosen't work. Do I need to place the leading edge of the rotor on #1 like the A? I have the proper B camshaft pin hole. No luck on the thread search.
Thanks for your help,
Pete
Peter J is offline   Reply With Quote
Old 01-27-2012, 02:33 AM   #2
J Franklin
J Franklin's Avatar
Default Re: B dist.timing
With the pin in the cam gear and the + - set at 0, set as a model a with the points just beginning to open. The timing doesn't care where the rotor is pointing unless something is way off.
Old 01-27-2012, 08:54 AM   #3
RonC
RonC's Avatar
The rotor has to be placed opposite the number 1 contact. There are 4 lobes on the cam. Positioning the rotor opposite number one will get you to the correct lobe to adjust your points off of.
RonC is offline   Reply With Quote
Old 01-27-2012, 08:59 AM   #4
Peter J
Peter J's Avatar
Thanks J,
I figured the cam in relation to the points was the key. I guess what threw me was the built in advance with the B timing pin hole. Not too much info. on the B's out there?
Pete
Old 01-27-2012, 09:02 AM   #5
BCCHOPIT
BCCHOPIT's Avatar
I did mine my ear and seat of the paints feel.
I did just buy some timing marks for the next time but it's been running great for 3 years now
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 01-27-2012, 09:29 AM   #6
Peter J
Peter J's Avatar
I guess the proper way is to get it in the ball park then do the fine tuning with the + 0 scale on the side. Probably should try a timing light as well just for grins.
Thanks,
Pete
Old 01-27-2012, 01:42 PM   #7
Greg way out West
Wink Re: B dist.timing
Hey Pete,,
If your using the B timming cover & dist,,,then you would just set the timming for a B engine.. just like setting the A timing
The 32 service bulletin's has the instruction's how to set it...The fine tuning is the bracket on the side of the dist.. + or -
Y/T Greg out west
Greg way out West is offline   Reply With Quote
Old 01-27-2012, 03:42 PM   #8
Marco Tahtaras
Marco Tahtaras's Avatar
Originally Posted by Peter J View Post
Hey Guys,
Pete
Oddly, you started a thread on this issue last June with several replies. Click HERE to view. I addressed your particular issues within that thread but you can see it HERE. Now, if you can set your spark lever as described you have the option to time it as I explain on my web site:
Model 'A' Ignition Timing
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-28-2012, 12:03 AM   #9
Peter J
Peter J's Avatar
Thanks Marco,
I think the confusion came from using an A dist. on a B engine. My question was the initial timing using a B dist. on a stock B engine. Today I set the points to break as the rotor meets the #1 cylinder. Seems to run OK.
Pete
Old 01-29-2012, 12:37 PM   #10
BCCHOPIT
BCCHOPIT's Avatar
If you have a B engine and want to run your old A dist. just put your A front cover on the B engine and all will work just like a stock A
