#1 |
I took my intake and exhaust manifolds off, and also my valve cover doing some cleaning on my engine block while I had the front end off and noticed that the block appears chipped / cracked around the exhaust valve guide. Can anyone tell me if this is common, or if it needs to be repaired, or can be repaired? Just how serious is this?
#2 |
That chipped off section of boss in front of the guide is not a problem, I've seen many and it happens hammering guides in and out. If you have peripheral radiating cracks that penetrate that may be a problem. Since the weak front edge of the boss is the only visible chipped area, I doubt there are more cracks. Not easy to see unless you clean off the carbon and use a penetrating dye. Don't obsess, if it runs well drive it.
#3 |
Like Mike said, it is fine as-is.
#4 |
Wick |
