#1 |
Hi,
Have been planning all the things for my car while I start my rebuild/restoration, and the wife is insisting on a heater being installed! I live in southern california where cold and weather is not a big deal, but late night runs to the local Bob's Big Boy can get a lil nippy. I am building a traditional 1940's style 29 roadster with V8-60 flathead. Just wanted to inquire what the best setup to with? Vintage out of another car of the era? Aftermarket? As you all know, looks and space consideration are a comcern.However an effcient, safe and reliable setup for a heater is the most important. |
#2 |
I would think that an Autolite bolt on hot air heater would be quite adequate in Cal.
It would require a hole in the firewall and the proper exhaust manifold. I hve one in my coupe and it is fine in New England as long as the tmp is over 25 deg. F. |
#3 | |
![]() Quote:
Do you have a picture of one? |
#4 |
Ialso live in california, have installed a heat and air cond. kit that i made up. warm in the winter and cool in the summer!! p.s dont have a wife but it keeps me happy.
#5 |
I'm not sure the manifold heaters will work on the V-8 Snyder's offers a heater that mounts on the firewall that uses water from the radiator and an electric fan. You should be able to adapt that to work. We actually put heated seats into the sedan and didn't install any heater.
#6 |
#7 |
Barry or Gar-Do either of you have a picture of your manifold? I had a "heater" type manifold on my coupe when I purchased it and I am trying to identify what brand of heater it is and what type of cover I need for it.
Thanks
Fred Kroon 1929 Std Coupe 1929 Huckster |
#8 |
There are manifold heaters for flatheads but the ones I've seen are complicated and ugly - plus manifold heaters are hard to regulate. Aftermarket places like Vintage Air sell compact hot water heaters but they're just black boxes. There usually are some vintage ones on ebay - they're just a small radiator with an electric fan but they usually have a cool art deco cover. They're mostly six volt but a twelve volt motor can be adapted with a little ingenuity. They can be recored but of course it's cheaper to get one with a good core. Otherwise, just refinish the cover as necessary. You can buy new rotary switches that look old-timey and allow you to vary fan speed - it also helps to put a shutoff valve in the water line.
For example, this one's currently on ebay - even looks like a Model A radiator: |
#9 |
I like the original 39-40 Ford hot water heaters - very functional and a nice classic 40's look.
#10 |
this is my HaDees heater in the 31 tudor
#11 |
Sorry, I missed the fact that the application was for a V-8-60. I did have an accessory manifold heater for my V-8 '34 Fordor but recycled it due to poor condition and the concern that I could not inspect it well enough to insure that I would not be breathing exhaust gas. I prefer hot water heaters for the early V-8s. There are many to pick from.
To answer the question for a picture of the Model A Autolite, it is below. It has been my experience that there must be at least three different patterns used for casting the exhaust manifolds. The varience is in the depth of the fins. The deeper the fins, the more heat transfer. Gar Williams |
#12 |
I would think finding a 40's style heater small enough to fit into a roadster and still allow your wife good leg room will be your biggest challenge. Once you have done that, make it safe and reliable.
I have not seen any of the aftermarket heaters, being sold lately, that would meet your criteria.
The only thing that can beat an attempt----is a failure!!!! |
#13 |
I built a custom under the seat heater for a friend of mine. I selected an oil cooler that would fit the space available from a J.C. Whitney catalog. Radio Shack sells a variety of 6 or 12 volt fans. From there it is a piece of cake.
Rainmaker Ron |
#14 |
I'm running both, an Autolite "bolt-on" manifold heater in pick up and an OTWELL manifold heater on the Town sedan. Only draw-back is with those type, you should have an aftermarket oil filler pipe "blow-by tube" also. Without one, I noticed some smoke in cab. I feel the hot water type are good, but they can make pulling front floor board out a hassle. Since we're on the topic, please forgive me for asking my question here on VCS2's thread, but what the heck are the 2 little holes for on the front end air intake of all the Autolite bolt on castings? Some kind of screen or cover?? I've never seen one but the holes are always there.
#15 |
i am building a 29 open cab ,basically stock looking,but plan on converting to 12 volt and making my own seats,being heated seats.gotta keep the wife warm.
#16 | |
![]() Quote:
#17 |
Wow! So many options and great information. I am actually using allot of 40 Ford parts in the car, without knowing the specifics, do you all think I could adapt something from the 40 sedanheater to a model A?
#18 |
I would do something like Rainmaker Ron did. I'd use any heater core from a junkyard and make my own box for it and mount it under the floor, then send the heat up through a floor grate. This way no interior room is used up.
#19 | |
![]() Quote:
#20 |
Nice period heaters used to show up at swap meets frequently (even in California). I must admit I haven't looked recently. Are you going to catch the Big Three swap meet in February in San Diego?
Charlie Stephens |
