Old 01-20-2012, 11:45 PM   #1
428Cobrajet
Default oil pan rear reinforcement
Fellow Model A Owners,
I am installing my oil pan and run into a problem.What holds the rear of the pan to seal against the back cork gasket. Am I missing some kind of reenforcement on the pan like on the front?. I dont remember having anything when I pulled the pan and I have looked everywhere in the garage.
428Cobrajet is offline   Reply With Quote
Old 01-21-2012, 12:12 AM   #2
mass A man
mass A man's Avatar
Default Re: oil pan rear reinforcement
No, I don't think you're missing anything. The oil-soaked cork gasket fits around the crankshaft cap, and comes up to the paper side pan gaskets. The flange at rear oil pan compresses onto the gasket. I usually use some Permatex gasket sealer to help seal everything. (The brown, sticky stuff).
mass A man is offline   Reply With Quote
Old 01-21-2012, 02:00 PM   #3
428Cobrajet
I got it on and used your suggestion with gasket sealer. It was a bugger to hold and compress the oil pump spring to start the bolts. Thanks for your help!!!
Old 01-21-2012, 08:31 PM   #4
columbiA
Put the side gaskets on the block first,then the rear cork.Use 4-1,1/2"headless bolts to keep gasket aligned & make it easy to push pan into place to get the bolts started.
columbiA is offline   Reply With Quote
