Old 01-19-2012, 09:40 PM   #1
buyitsmart
buyitsmart's Avatar
Default Smoke in the cabin of my 31 Coupe
Can anyone tell me why all of a sudden I am getting a lot of white smoke inside the cabin of my coupe when I accelerate? Based on the smell it is definitely burning oil and not an electrical problem.
I did an oil change a few days ago and I have been driving the car a little hard but I don't see any oil leaking on the exhaust manifold or exhaust pipe. I do have some oil coming out of my oil filler cap but it doesn't seem to be getting on anything that would cause it to smoke.
How do I keep the oil from coming out of the oil filler cap and getting all over the engine and engine pans?
Fix it like you know you're gonna drive it.
buyitsmart is offline   Reply With Quote
Old 01-19-2012, 10:13 PM   #2
Dick Deegan
Dick Deegan's Avatar
Default Re: Smoke in the cabin of my 31 Coupe
Check the bottom bolt at the rear of the valve cover and the bolts/gaskets on the oil return pipe on the valve cover.
If they leak your fan may blow the oil particles onto the exhaust manifold and into the cab via air leaks etc. It has happened to me.
I use some ss wool as used in the kitchen to clean pans etc. and put it into the oil filler cap to stop oil mist from escaping onto the engine pans and the starter motor. Make sure that it is properly secured in the cap.
Dick
Dick Deegan is offline   Reply With Quote
Old 01-19-2012, 10:38 PM   #3
Dusty
Dusty's Avatar
Why was Funky Claude throwing kids on the ground? were they on fire?
Snowing here in Wild and Wonderful WV-- Coupe resting comfortably in a 65 degree garage
dusty
Dusty is offline   Reply With Quote
Old 01-19-2012, 11:09 PM   #4
'lilredcoupe
'lilredcoupe's Avatar
Send a message via AIM to 'lilredcoupe
Could possibly be blow-by.
Rob Kellogg
Cazenovia, NY
'lilredcoupe is offline   Reply With Quote
Old 01-19-2012, 11:56 PM   #5
700rpm
700rpm's Avatar
dusty
Well that explains it!
Ray Horton, Portland, OR
Old 01-20-2012, 01:50 AM   #6
Geo. H
How much oil did you put in when you changed it?
Geo. H is offline   Reply With Quote
Old 01-20-2012, 09:28 AM   #7
V4F
V4F's Avatar
i have to run mine a little over full (v8 oil pump) . i used to get some out the filler untill i put a K&N filter on it . i am also installing a 'pcv' valve because when i go a long distance at 60-65 mph , it seems to build crankcase pressure . just my ideas ............. steve
V4f
V4F is offline   Reply With Quote
Old 01-20-2012, 12:11 PM   #8
1930artdeco
1930artdeco's Avatar
You can always build a road draft tube out of PVC pipe like someone on the barn did. Just do a search for 'fumeaze'
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-20-2012, 08:52 PM   #9
columbiA
If rings are good,there should be no blow-by at all.If you are useing anti freeze and have a head gasket leak it will make a lot of white smoke,while oil burning will make blue smoke &very rich fuel mixture will produce black smoke.
columbiA is offline   Reply With Quote
Old 01-20-2012, 08:58 PM   #10
C26Pinelake
I also had white smoke in the coupe and it was as stated above, it was a leaking head gasket !
C26Pinelake is offline   Reply With Quote
