06-23-2010, 12:33 PM | #1 |
Water pump roller bearing
Anybody know of a number for the modern equivalent of the model A
waterpump front shaft bearing?? Thanks |
06-23-2010, 12:57 PM | #2 |
Re: Water pump roller bearing
Torrington B-1416 for the needle bearing, and IR-1016 for the inter race.
The needle bearing will very nicely slip inside the original roller bearing outer shell. jb |
06-23-2010, 03:25 PM | #3 |
The last time I built a pump with the B-1416-OH, I cleaned all parts thoroughly and used LocTite 620 (Cylindrical Assembly Retaining Compound) at the pump/shell and shell/bearing interfaces. In the fall I will take the pump apart and see if everything stayed put. Joe
1929 Tudor since 1962 Feather River A's |
