#1 |
switching over to 12 v, put a new electronic dist. on and the cap doesnt clear the stock fan belt.
wondering if anyone else has found a 12v fan that comes close to mounting on the stock radiator thanks for any ideas some days nothing seems to go together without a fight |
#2 |
Mounted a Ford Escort on the front of my 46 radiator, just needed a couple of angle brackets to mount it, works fine.
Dave |
#3 |
SPAL makes a good fan, pusher and puller, and have used pusher on my 41 truck and have a puller for my 50 car. good support brackets also. a little pricey but pretty quiet when operating... don
#4 |
Mainiac239, spal fans are good, they are quiet, be cause of curve to blade ,they are both pushers and puller, meaning that blade can be fliped over , Harold,Ca.
#5 |
I'm a Spal fan believer also. They make a great fan. Do the research,as they make a number of thin fans that have good air flow.
[QUO[/QUOTE]no matter where you are,or where you're at, there you are... ![]() |
#6 |
http://www.jalopyjournal.com/forum/s...ghlight=taurus |
#7 |
small world , went to the repo lot today and came home with a taurus fan
it was also the easiest one to get out |
#8 |
here's my set-up on the '47, stock fan won't clear the msd. just put a new Flex-a-lite S-Blade Low Profile on (after this pic).
