Old 12-24-2011, 07:14 AM   #1
blown49
blown49's Avatar
Default Stock Ford cams
Any body out there have a chart on the spec's of the various cams used in the flatheads?
TIA
Jim
Visit my Blown '49 Merc website @ http://www.blown49.com
blown49 is offline   Reply With Quote
Old 12-24-2011, 09:01 AM   #2
Elmo Rodge
Elmo Rodge's Avatar
Default Re: Stock Ford cams
Jim, here's a start with some stockers. Wayno
49-51 ford "B" cam
.305 lift
int. opens 5*btc - closes44*abc set.017
exh. opens 48*bbc -closes3*atc set.019
52-53 ford "E" EAB cam
.328 lift
int. opens 21*btc - closes68*abc set.017
exh. opens 56*bbc - closes11*atc set.019
49-50 merc "8CM" cam
.338 lift
int. opens 10*btc - closes50*abc set.014
exh. opens 50*bbc - closes10*atc set.016
51-53 merc "1CM" cam
.333 lift
int. opens 5*btc - closes51* abc set.017
exh. opens 47*bbc - closes9* atc set.019
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 12-24-2011, 09:05 AM   #3
Elmo Rodge
Elmo Rodge's Avatar
Jim, here's the DeLong in my Bonneville car.
DE LONG RACING CAMS
GRIND # 7212-16
SUPER FULL RACE
INTAKE OPEN 34 B.T.C.
DURATION 288
INTAKE CLOSED 74 A.T.C.
EXHAUST OPEN 78 B.B.C.
DURATION 288
EXHAUST CLOSED 30 A.T.C.
.368 LIFT
VALVE CLEARANCE INTAKE .014 EXHAUST .016
Old 12-24-2011, 10:10 AM   #4
Ole Don
Ole Don's Avatar
I sure do want to hear that one run, will it be a Speedweek, or WOS in 2012?
Ole Don is offline   Reply With Quote
Old 12-24-2011, 11:06 AM   #5
Elmo Rodge
Elmo Rodge's Avatar
Hopefully both Don. Now back to our previously scheduled programming. Wayno
Old 12-24-2011, 12:57 PM   #6
Craig CT
Craig CT's Avatar
TIA
Jim
Hi blown49; Tilden Technologies.com Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 12-26-2011, 08:15 AM   #7
blown49
blown49's Avatar
Thanks for the info fellas, it's much appreciated.
Jim
