#1 |
I know this may go against the grain for some... but having heard the stories of trying to keep the glass in the brackets and knowing the many things that can happen when the glass falls out...
I've found a place to have the wings made from acrylic motorcycle windshield material. Figure it's lighter, less destructive if it should fall out and lends itself to other ways to secure it (e.g. easily drilled thru for a set screw). Edges will be polished for a good look. I just need the measurements/template to get them the right size and shape. Anyone willing to trace the pattern and post it with measurements (including thickness)? Thanks in advance.
- bogie '31 (Mostly) Roadster |
