#1 |
For about $20 at Walmart I picked up a combo brake-turn-tail LED lite.It was about 2" x 6" and is 12 v neg grd.On my 6v + grd car,Iused the grd wire as the hot wire & brake wire as grd wire.I centered the lite on bottom of rear window & glued it on with dab of clear silicone on each end. Simple matter to run wires behind back rest down to brake lite wire &grd.
#2 |
#3 |
Reversed the wires since polarity is Pos grnd in a stock Model A
#4 |
Did it work???
#5 |
yes ,LED brake lite works great.
#6 |
Matt from central Jersey |
#7 |
They won't be as bright at 12 volt, but it'll still work good. It doesnt take hardly any power to run led lights
Cowtown A's |
#8 |
I would love to see some pictures.
Style beats speed any day, and with a lot fewer tickets. |
#9 |
The 6 volt THIRD BRAKELIGHT I purchased from the fellow in Connecticut, is it J&L works just perfectly, with scads of brightness, and does my directionals, to, and as I recall its like $35.
Its about one inch high and probably 14" wide. |
#10 |
Can you post a picture of it. I might run down and pick one up.
#11 |
Not sure I was able to follow which you were requesting the picture of... but here is the link to the J&L model Bruce referred to
http://jandlenterprise.com/products/brakelighter.htm
- bogie '31 (Mostly) Roadster |
