05-08-2010, 07:09 PM | #1 |
need right 21 stud head
City:
Rapid City
State:
SD
Hello i have a NORS drivers side aluminum (for domed pistons) head stamped 68-6050. I need a passenger side aluminum (for domed pistons) head stamped 48- or 68-6049-?. I have a 1936 Ford LB in machine shop getting bore job ect and i only have the one head. thank you.
05-09-2010, 03:36 PM | #2 |
Re: need right 21 stud head
a 48 head is for a '35 with flat top pistons. a 68 head is for a '36 with domed pistons.
Best to use domed pistons and '36 head son either '35 or '36. You can NOT use a #48 head on an engine with domed pistons. The dome will hit the head. If your machinest ordered flat tops then you better use a pair of 48- heads. Otherwise the compression will be very low. |
05-09-2010, 09:26 PM | #3 |
yes i am using domed pistons so you are correct i need a pass side head for domed pistons...i cant seem to locate one...according to the book 'the early ford v8 as henry built it' the domed heads started experimentally in 1935....so perhaps i could find one with 48- or 68-
05-10-2010, 03:56 AM | #4 | |
05-10-2010, 03:48 PM | #5 |
Thank you DaveD for the updated info....the search continues...
05-11-2010, 04:56 PM | #6 |
05-12-2010, 11:00 PM | #7 |
Chris thank you for the response...
05-13-2010, 12:44 AM | #8 | |
