Old 12-09-2011, 01:12 PM   #1
Fred A
Fred A's Avatar
Default Fuel Pump Noise?
On my '47 changed the carb AGAIN and before bringing the idle up to normal, noticed that there was a light knocking, most notable while barely running at low RPM. Now that it has been discovered and several other noise sources have been cured I can now hear the tapping from a few feet away. Broke out the stethoscope and found it to be the Chinese fuel pump or the push rod. Does this lead to damage or failure in the Ford? Sure don't want to get into any more phantom problems while concentrating on other more worthy projects, but depend on this car to go to events while doing as little as possible to maintain. Thanks: Fred A
Fred A is offline   Reply With Quote
Old 12-09-2011, 01:49 PM   #2
JWL
Default Re: Fuel Pump Noise?
A portion of the baffle system includes a tube which fits into the bottom, center, of the fuel pump mounting stand. If that tube happens to fall out of the stand it can create a noise problem.
JWL is offline   Reply With Quote
Old 12-09-2011, 01:56 PM   #3
ken ct
This can happen but have never seen it. Could be the baffel tube in wrong and ive heard some pumps are a little noisy. I wouldn't trust a China made FP as far as i could throw it. Have an original rebuilt with USA parts "AC" brand. ken ct.This should be a glass bowl type.
ken ct is offline   Reply With Quote
