Old 11-29-2011, 12:10 PM   #1
quabbinman
Default 36 crank out windshield,need info
I have a 36 slant,
The previous owner installed the windshield without the crank and hinges,so it is fixed...I have a nice crank and pair of hinges,but have know idea how to do the job...Is there a manual showing the parts and procedure to do the job...or does anyone know someone near central MA.that could do the install for me...Thank You...
quabbinman is offline   Reply With Quote
Old 11-29-2011, 01:18 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 36 crank out windshield,need info
You need about 6 holes thredded in the to of the screen to take the hinges and 2 in the bottom to take the bracket for the crank .if non you could maybe retap the threds or mig weld them .once they are attached you can screw the other half onto the hedder and fit the crank in behind the dash ,might need to remove the dash .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-29-2011, 01:27 PM   #3
PeterC
PeterC's Avatar
Curious - how was it "fixed"? was it glued in? Are the original hindge and crank holes still visable in the WS frame and body mount points?
PeterC is offline   Reply With Quote
Old 11-29-2011, 03:10 PM   #4
richbud37811
i have a very nice windshiled frame if you need one 125
richbud37811 is offline   Reply With Quote
