Old 11-02-2011, 09:58 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default Frame Stiffeners??
Here's one for you guys. My '30 Town Sedan was restored about 45 years ago. It has half inch bars welded to the frame by the front axle and ending by the rear end. The bars are held below the frame by angle iron about 3 inches long welded vertically between the beginning and end of the bars. In the middle of the bars,between the angle iron, are turnbuckles on each side. It appears that you could stiffen the frame by turning the turnbuckles. I am the fourth owner and the man I bought the car from, twenty years ago, said the original owner drove the "A" in the oil fields in West Virgina. Could these have been installed to fortify the frame?
The frame looks very sound to me and I'm considering removing these turnbuckles. They don't hurt anything but they make it hard to install an exhaust system and it's close quarters on the left side by the battery.
Anybody out there ever heard of this?
marty in Ohio is offline   Reply With Quote
Old 11-03-2011, 02:48 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Frame Stiffeners??
This was a common sight on older railroad cars for added strength, but I've never heard of it being done on a Model A. I'd remove the bars and make sure the frame has no cracks.
Old 11-03-2011, 08:35 AM   #3
1931 flamingo
1931 flamingo's Avatar
Depending on where you are with assembly/dis-assembly, it might be easier to get another frame.......JMO
Paul in CT
Old 11-03-2011, 10:13 AM   #4
Jim Brierley
OR ... if it ain't broke, don't fix it!
Jim Brierley is offline   Reply With Quote
Old 11-03-2011, 02:58 PM   #5
marty in Ohio
to Paul in CT. I'm not assembling or disassembling, I have had this car for twenty years and these "stiffeners" have always been there. I think I may take Jim 's advise and do nothing about them. Thanks for all the messages, guys.
